wastegate/bov help
Old Nov 11, 2007 | 12:14 PM
reamo04's Avatar
wastegate/bov help
what size of wastegate and BOV would be needed for a 355 running 15psi max.
im assuming a 40mm wastegate, and 40mm BOV?
other wastegate sizes :50mm, 60mm
other BOV sizes : 56mm
(using JGS)
also, how well would like a tial 38mm BOV work? or shoudl i stick w/ the JGS?
Old Nov 11, 2007 | 12:29 PM
FireChicken1995's Avatar
depends on the turbo setup too... if its a sts a 38mm waste gate would be ok. im gonna be running 15lbs on a 383 and have a 46mm that RealQuick said would be better than the smaller stuff he usually used. BUT my kit is a lil different than others. i would say 38-40mm waste gate.
for the BOV i have a tial 50mm it should do the job just fine w/tons of room to spair. i mainly got it b/c of the design.
Old Nov 11, 2007 | 01:10 PM
leadfoot94's Avatar
Turbosmart Ultragate: 38mm - Should work fine on higher boost apps.
Tial 50mm BOV
