Help me out
Old Sep 16, 2007 | 01:43 PM
BLWNLT1's Avatar
Help me out
Any one now how to figure this out.
Blower pulley ratio = crank pulley diameter / blower pulley diameter x the internal step up ratio = blower RPM. You get the most out of the blower relative to the speed of it.
What I have is a P600B no after market pulleys or anything like this.
I will how ever ask what pulleys are available to get the max out of this blower.
Old Sep 16, 2007 | 09:42 PM
Boosted_Z28's Avatar
Your question seems a little unclear...are you asking how to calculate the engine rpm your blower will be maxed out at given the diameters of the pulleys used???
Old Sep 17, 2007 | 04:26 AM
rskrause's Avatar
Moderator
To calculate impeller rpm: blower pulley/crank pulley x internal gear ratio = impeller rpm. For a P600B, the ratio is 3.05:1 and the max impeller rpm is 60,000. There are lots of pulleys available from Procharger and other sources. If you want a rough way to guesstimate boost you will see from maximum rated cfm, go to: http://www.kennedysdynotune.com/ and under the Tech Tips dropdown, go to "Calculating Blower CFM". I now realize I misnamed that and need to title it "Estimating Boost from Blower CFM"
Rich
Old Sep 17, 2007 | 09:03 AM
BLWNLT1's Avatar
Rich
