View Full Version : N2O Tech
- what do i need?
- We are Back and Its a new year!!!
- Paging Nitro Dave
- nitro question
- ideal com ratio
- Rings
- N20 Daves LT1 Plate Kit??
- Fuel question
- Broke piece on NX nozzle
- Fjo Clearence Products...
- What do you guys think of Comucar N20 system?
- Progressive Controller special!!!!
- Greg here is your intake...
- Fuel system
- How much juice with boost
- Nitrous in the Desert
- New to nitrous... looking for a lot of general help/suggestions...
- Preparations
- possible detonation from previous owners N2O
- Would it be ok to run a nitrous kit with no bottle heater?
- Shark nozzle in Trick Flow Elbow?
- whats involved in installing a fogger kit on a s.b.c. 350???
- instructions and/or pics
- Zex wet nozzle? Nitro Dave Please assist!
- two stage n2o
- Plate+nozzle 2 stage questions
- About to jump into the nitrous game, just have a few questions.
- got a few questions
- Intake manifold for Nitrous - question
- Nitrious help!!!!
- switch ideas
- LT1 Switch ideas
- Direct port LT1 kit Qs
- Holley Throttle Body W/ Nitrous inlet - Anyone try this?
- Debating on what to do with the nitrous? Yes, i don't know anything about it.
- Lt1 Times
- Solenoid Frequency??
- Who Wants free Car?
- Any kits compatible with lt1 AND ls1
- Got a N.O.S. kit, what to do???????!
- Shark Nozzle Jetting
- modifying nitrous works kit?
- ideal comp ratio???
- what gears with nitrous
- Silencer plug with nitrous nozzle hole?
- plate or nozzle?
- whats the best wet kit for lt1????
- Christmas Specials!!!
- how much juice can a bolt on lt-1 take
- many nitrous questions from a juice newb
- Cam LSA and Nitrous
- Went to the track tonight...new best time
- NOS bottle question
- dry n20 jets
- LT1 Nitrous question
- Thanks Nitro Dave
- Retard Timming
- What cam to use with NOS
- Paging Nitro Dave
- Is this a joke?
- Thinking about building a nitrous-specific engine...
- should i use or should i leave alone?
- stock clutch + street tires + 100 shot
- Heater pressure switch tab broke...this happen to anyone else?
- n00b Nitrous Oxide question for you pro's!
- Thanksgiving Site Wide Sale
- Strange AFR problems...
- New Product....
- Almost went 11's..
- 175-200 shot, 255lph enough?
- Wet plate vs. wet fogger
- bending blowdown tube / purge kit questions
- when to upgrade fuel lines?
- Varible Ramp Progressive controller.
- anybody useing nx part# nxmaf-ds
- your guestamets plz
- LT1 intake question
- car running rough after plug change!
- converting zex dry kit to 150 hp
- i have a few questions about nitrous....
- running out of nitrous at WOT
- sniper kit
- HSW Progressive questions
- Cam and wet kit - injectors?
- How to run the wires??
- JE Plasma-Moly vs Hellfire rings. Need help
- The 860 Deal!!!
- bringing system back to life
- FJO mini controller
- turbo with N2O
- Piston ring thickness
- Anyone have these?
- Nitro Dave Help Plz
- Nitrous Outlet Plate System Prices.
- 100k mile or more LS1's in here
- stupid purge question
- will the stock fuel pump be enough?
- nitrous on a madz28 tune
- LT1 window switch tach signal problem
- how much HP a stock LT1 handle?
- Fuel Line Hookup
- Getting a nitrous kit. Please help this new guy out.
- Who here has used a dry kit SUCCESSFULLY?
- need some nitrous and tuning advise
- Single nozzle location on 96 WS6 TA?
- mallory 685
- Plug heat ranges...
- Afpr?
- Largest purge kit.
- Stock bottom end??
- Mounting nozzles in the intake...
- what is needed to run 15o shot on lt1
- wiring question
- 1/4 mile times for stocker?
- nx 20920 efi stage 1 and 20118 whats the differance?
- lt1 wet kit
- Direct port rubber lines?
- my lt-4 direct port intake/set-up on ebay
- LT1 plate pics..
- Best LT1 nitrous kit for the price
- About to spray wut do i need to check
- what plugs to use with nx n20
- 2800...3.73...cc306
- Is this plate homemade?
- Can I get away with 200 on my setup this way?
- Could i do this?
- Nitrous filter change?
- Will high octane save my butt for now?
- Free shipping on W.O.T. Switch brackets and TPS activation switches!
- Where to buy a Nitrous plate>>
- timing+air/fuel???
- NX bottle opener whats the diff black or purple?
- Headgaskets
- Would anyone be interested in a solid state nitrous control box?
- Could I use this switch...
- racetronix kit
- Anyway to wire bottle opener like a power antenna???
- what spark plug do ya need for nitrous?
- Fastest stock long block
- Is my air/fuel okay for a 100 shot?
- Hidden N20 Setup
- What Nitrous kit?
- MSD 8969 with LS1 question
- 250 and more ??
- Anyone using a 250 shot with a t-brake?
- Nitrous Special..
- New product....
- Best Way to Plug Nozzle hole
- Easiest way to get window switch/progressive/timing retard
- Paging Nitro Dave
- Nitrous Cam
- Cold Fusion, best price?
- Plug recomendation and gap?
- plumbing a fogger kit
- RPM Activated Switch
- N2O and compression ratio
- MSD6 BTM with n2o (also do I need new fuel pump with wet kit???)
- N2O and Emissions
- New!!! 860 Performance Product...
- ls6 intake/ direct
- Stock pistons+nitrous???
- What system for my LT1? Just want a little shot!?
- Stock LT1's with a 100-150 shot
- Is it worth it?
- how to hook up fpss?
- My nitrous kit doesnt work anymore!!!
- Best N20 kits?
- Look!!!
- Purge pics?
- Nitrous feel?
- TNT, jets for 125 shot?
- What jets are you guys running for various hp settings?
- Am I running out of fuel? Opinions please.
- walbro 255...yall guys know!
- Nitrous Timing
- NX install help
- All Fordged...How much spray?
- Gerneral N2O question
- New TPS switch, The Trigger!
- lt1 with 42lbs injectos and MSD (dry or wet???)
- What to upgrade with 75 shot
- NEW Nitrous Progressive.... MULTI-POINT RAMP
- Getting my first N20 system
- looking for a 4150 style wet n2o plate
- Lots of Nitrous, Lots, what 2 stage system 2 use.....
- stock motor lt1....over 100k miles...? bad idea?
- juice on stock motor
- methonal w/n2o
- The Mark! Digital nitrous bottle contents indicator!
- whats safe for my car as far as nos
- Strange problem
- What nitrous Kit for me?
- knock sensor
- Nitrous Nitrous Nitrous
- New LS1/LT1 plate systems!!!
- Can you run msd dig window switch with delteq?
- Window switch question
- lt1 wet vs dry
- Questions about solenoid bottle openers
- Another New Product! The Angle!!!
- TnT LT1 kits - how to tell between F1 & F2
- Custom Billet micro switches...
- Best nitrous plugs..
- New Product!!! Progressive Nitrous Controller
- What'll I need to handle a 300 shot?
- Anyone running "concealed" nitrous kits???
- Remote Bottle Opener problems
- Direct Port Results?
- The Rolling Nitrous Store!!!!
- Jetting for Sportsman fogger system....
- Activation RPM w/3400 stall?
- Help w/ jet numbers ??
- Installing wet kit, tnt F1
- Jeff Prock Lt-4 intake, direct port for 300-600 shot f/s
- instruction question
- The one week sale.....
- question on solinoids
- 10% Off All Nitrous Kits!!!
- Where to buy Gone in 60 Seconds style Nitrous Switch Panel???
- N20 Holely TB.
- Zex LED purge illuminator
- Paging LT1 5176 nos dry kit users - need jet info
- Nitrous pressure gauge installation?
- What's the Amperage of the Zex wet kit fuse?
- !!new Safety Part Coming Out From Nx!!!
- Guys running hot cam and Nitrous read
- Nitrous plate on LT1
- Nitrous on my 02 SS
- Should I use the bottle or not??????
- A Nitrous question on my 95 Z should I use it or not?????
- Ngk Tr6
- August Nitrous Specials...
- Anyone have the Nitrous Comp Cam?
- 175 shot...whats needed?
- Help With Install
- How much?
- Nitrous with timing advanced 24?
- "hot wired" fuel pump?
- Fuel Pump.
- too rich?
- How much nitrous?
- nitrous cam
- 100 shot with bolt-on tune???
- -6 Feed Line or Two Bottles
- Fogger Question
- Leaky NX fuel solenoid?
- Thinking about Nitrous
- What are purge kits (LOL)
- Clean Look
- nos stage 2 question?
