Afpr?
Old Oct 26, 2005 | 06:12 AM
ejfagala's Avatar
Afpr?
I removed my AFPR about a year ago because once I started tuning I found I didn't need it is there any reason I need ot if I am installing a wet kit? I plan on installing a 125 shot wet kit and having a Nitrous only tuned ECM so I can maintain my stock ECM for every day driving and have a nitrous ECM that will be a bit fatter with fuel and have timing pulled for WOT in the RPM range the window switch will be set for. Can't I just change fuel jets and add or subtract fuel to the PE table to get the proper A/F instead of messing with a AFPR?
Old Oct 26, 2005 | 07:27 AM
LWillmann's Avatar
Re: Afpr?
Yes, you can play with the fuel jets to get the desired AFR.
Question: Why run a second PCM and swap them? Why not get an ignition box that has a timing retard feature, and do all your fueling changes with the fuel jet?
Old Oct 26, 2005 | 10:01 AM
ejfagala's Avatar
Re: Afpr?
I have the Delteq system and I believe the only box that will work is one of the MSD products and it requires a bunch of expensive modules to make it work (want to say around $800). I have a spare ECM and it only takes about 5 min to swap.
Old Oct 26, 2005 | 10:56 AM
LWillmann's Avatar
Re: Afpr?
Fair enough. I didn't notice the Delteq in your sig.
Fastbird93
Sep 29, 2015 04:05 PM
Drtryder
Apr 22, 2015 04:17 PM
87Aerocoupe
Mar 20, 2015 01:23 AM
CobraEatr
Jul 24, 2004 11:37 AM
teke184
Jun 19, 2002 04:42 PM
