FJO mini controller
Old Nov 7, 2005 | 07:22 PM
ejfagala's Avatar
FJO mini controller
Just got a new toy in the mail from Dave, a FJO progressive mini controller. This thing is way to cool and I now can't wait to get the darn nitrous installed (waiting on my solenoids to get back). It was only $200, about the cost of a TPS and Window switch.
Check out some of features
TPS controlled window switch, (no need for a mechanical switch here)
First gear lock out
RPM cut off
RPM trigger
Two stage progressive control (I will only be using stage one for the moment)
Time based or RPM based progressive curve so you can bring the nitrous on progressively and you can use software to adjust the curve with. The software allows you to smooth and raise progression lines with in the curve to adjust the nitrous progression instead of a straight curve selection.
Old Nov 7, 2005 | 07:32 PM
Nitro Dave's Avatar
Re: FJO mini controller
First gear lock out
RPM cut off
RPM trigger
Glad to see you got it. We installed one of those on my 99 this weekend. The features it has and the easabilty of programing is awesome.
Dave
Old Nov 7, 2005 | 07:54 PM
ejfagala's Avatar
Dave
Dave,
are you running a single shot or a dual stage? any problems with the coil pack/Tach signal?
Here is what I want the system to do, am i an the right track?
Single stage
1. window switch 3000 - 6000 RPM'S (Using the TPS and Tach signal)
2. Progresive control RPM based curve
3. First gear lock out or I will go to a time based progresion
IndyZman
Oct 22, 2015 02:17 PM
PopoFormula
Oct 12, 2015 04:19 PM
Louey
Pacific
Oct 1, 2015 12:37 AM
Stephen68
Parts Wanted
Sep 27, 2015 06:42 PM
drt
Sep 27, 2015 04:39 PM
