The Mark! Digital nitrous bottle contents indicator!
Old Sep 11, 2005 | 02:39 PM
HarrisSpeedWorks's Avatar
Pricing will be set around $240.00.
Old Sep 12, 2005 | 05:56 AM
Capt'n Two Rotors's Avatar
Re: The Mark! Digital nitrous bottle contents indicator!
that looks pretty cool what is instalattion like and how does it work? Figures off of flow or what?
Old Sep 12, 2005 | 03:46 PM
So how does it work? First you need to know how your nitrous kit is triggered; it’s either off a ground or a 12v. No need to re-wire anything, as The Mark will work with either. The Mark will ask for the size of your nitrous jets and the weight of the nitrous in your nitrous bottle (10 Lb N2O bottle has 10 Lbs of N2O when full, 15 Lb bottle has 15 Lbs of N2O when full and so on). When your nitrous system becomes active The Mark will know how long the Nitrous solenoid was open (The Mark will work with progressive controllers that pulse the solenoids) and do the math on how much nitrous was used, as it knows what jets you are using, and provides how many pounds are left in the nitrous bottle. The temperature thermostat takes temperature into consideration so The Mark will give you an accurate reading no matter what the bottle temperature is. After getting your nitrous bottle re-filler or topped-off you need to tell The Mark so it can give you an accurate reading.
Matt
Old Sep 13, 2005 | 10:14 AM
LWillmann's Avatar
How does it take purging into account?
Old Sep 13, 2005 | 12:31 PM
2 options at this point. One is a wire to go to your purge and the orifice can be set (pre set from the factory for CFN purges) or a purge amount can be taken into consideration and automatically be included in the math. Going nuts with the purge and using the second option will cause The Mark to loose its Mark. With The Mark set up for option 2 it's good to .25 of a pound.
Matt
RUENUF
Mar 13, 2016 03:37 PM
Quickss96
Jan 29, 2016 05:56 PM
z28newbie
Sep 9, 2015 10:26 AM
ChrisFrez
Sep 9, 2015 06:52 AM
Steve69SS396
Track Kill Stories
Aug 17, 2015 08:48 PM
