Direct Port Results?
Old Sep 1, 2005 | 09:09 PM
ChrisUlrich's Avatar
I know this is a very crummy question but...
Lets say the motor puts down 430/400 as a bench mark.
You spray a 250 direct port nitrous shot.
I know you should gain around 250rwhp... but what about torque? I always notice that the torque is just ridiculous on nitrous.
btw... it's a 6 speed. 383 LE3 with 11.8:1 cr (9:1 dcr)
Old Sep 1, 2005 | 09:36 PM
sniffin94's Avatar
Re: Direct Port Results?
it varies a lot from kit to kit but with 250 jets in the car I would at least expect 300 t/q probably closer to 320
Old Sep 28, 2005 | 10:11 PM
No one else?
Old Sep 28, 2005 | 11:25 PM
RacerTim's Avatar
Gimme a couple weeks....
http://youngstownstreets.com/gallery/Nitrous
Old Sep 29, 2005 | 08:17 AM
No one else can give an opinion?
Old Sep 29, 2005 | 10:46 AM
Generally the torque gain will be about 1.25 - 1.5X the HP gain. Of course, the lower the RPM the larger the torque gain...... but don't get greedy, because that's why things break at low RPM.
Old Sep 29, 2005 | 12:31 PM
I wanted to spray right after the 60ft... or maybe once I reach my window set at 3400-6400...
I am curious to find out if a 200 shot at least will put me over the 600rwhp mark and what kind of torque.
Old Sep 29, 2005 | 04:08 PM
JordonMusser's Avatar
West South Central Moderator / Special Guest
Just put the jets in that make the power/TQ you want. people get to caught up in "XXXhp jets, bRO!" instead of looking at actual nitrous flow into the motor- or better yet, what power it makes.
If you want to make 600rwhp, jet it till it makes 600rwhp.
Old Sep 29, 2005 | 06:16 PM
You're right... thats not a bad idea. hahahaha
But now let me ask this question. Lets say the rings were gapped for a max shot of "250."
You dyno 400/400. Put in your "250" jets but only make 200/200 at the wheels. Do you have the head room to install the extra 50 or are you stuck with what ya got? Since you're only gaining 200/200 from the 250 jets.
mightymouse383
Jul 20, 2016 07:34 AM
DSMKilla
May 26, 2015 10:10 PM
TitoPR221
May 26, 2015 12:20 AM
alex5366
Feb 17, 2015 08:12 PM
bandit383lt4
Dec 21, 2014 09:12 PM
