knock sensor
Old Sep 10, 2005 | 02:13 AM
camaroKid223's Avatar
knock sensor
Just a quick q for you guys, is it safe to run knock sensor delete with a 150 wet shot?
Old Sep 10, 2005 | 08:32 AM
Re: knock sensor
Depends on how good and how conservative the tune is. I run a 300-shot with no knock sensor, but the tune is backed up with more than 40 dyno pulls, and when I spray 300 the fuel comes out of a drum of C16 of known quality.
Old Sep 10, 2005 | 11:03 AM
Re: knock sensor
mail order tune, never run below 93 norm run sunoco 94 and plan to mix 100 in when im going to be spraying. safe?
Old Sep 14, 2005 | 01:04 PM
Hawk's Avatar
Re: knock sensor
I'd pull a few degrees of timing, 4-6 when your spraying you should be good.
Brian
KYWes
Jun 14, 2022 06:52 AM
350350
14
Aug 11, 2015 12:03 PM
HectorM52
Parts Wanted
Aug 8, 2015 08:12 PM
Noct
Jul 14, 2015 01:18 AM
asilomar244
Jul 12, 2015 05:53 AM
