Cam and wet kit - injectors?
I'm putting a CC306 in a car with a wet kit (stock heads). I'll be upgrading my fuel pump with the Racetronix kit, but should I get bigger injectors as well? Since it's a wet kit, obviously the larger injectors weren't a necessity for a bolt-on car, so I kept the stockers. What about after the cam goes in? Should I upgrade to 30lb injectors or will the stock ones be fine?
Re: Cam and wet kit - injectors?
Another vote for yes, it wouldn't hurt to upgrade them at this point.
Matt
Matt
Originally Posted by Kreinmc
Stock will be fine. You will make 355rwhp at the most with the 306/stock heads and the stock injectors should easily support that kind of power.
Originally Posted by Jameslt1TA
I agree. Friend on here is running a 306 with ported heads and 200 nx shot and running 10.19 on the stock injectors.
Yes check the duty cycle on the injectors.Mileage plays a factor here also. If the injerctors are worn out they will have a high duty cyle also.
The stock injectors should be ok other wise.
Dave
Dave
ezcheeze15
Aug 26, 2002 01:28 PM
ezcheeze15
Aug 8, 2002 12:27 AM
