About to spray wut do i need to check
i have a 150 wet shot all bolted into my tpi car. i currently have the timing advanced, were do i need to set it, wut do i need to check for and what do i need to replace to spray as safe as possable??
Re: About to spray wut do i need to check
well you wanna retard the timing, idk how much soem one else might have some good advice for that. also make sure you have gauges and the bottle pressure is correct before you actually start spraying. just all the general thigns that make nitrous work properly.
Using a wet kit..you have to make sure the fuel pressure is there. My advice would be a fuel pressure gauge and a fuel pressure safety switch. If your pump can't handle the 150 the switch will catch it and kill the system. Just my .02
i wish i could... i have the kit and justa jet for a 150shot.. its on the tb plate so i dont need a afpr. fuel pump is 50hrs old. i'm leaveing for basic training next monday so i dont have to much time to play with 2 much. the block is junk, i jus dont want to get 1 shot off and crush my valves or sumthin
teal98
15
Sep 16, 2002 01:23 PM
danielbmx
Aug 27, 2002 11:11 PM
johnsocal
21
Aug 17, 2002 01:06 AM
SilverWS6
13
Aug 14, 2002 09:29 PM
newby
10
Jul 27, 2002 11:39 AM
