NX bottle opener whats the diff black or purple?
Old Oct 11, 2005 | 10:46 AM
94Zpower's Avatar
I just picked up a NX bottle opener, it's black and I havee seen others that are purple, whats the difference?? is on beteer than the other or just a newer model???
Thanks.
Old Oct 11, 2005 | 03:33 PM
BlownF1's Avatar
Re: NX bottle opener whats the diff black or purple?
Well, since nobody else has answered yet...I'll offer what little I know.
I've only seen 2 versions of the NX opener...both were purple...not to say there couldn't be another, but I've never seen or heard of one.
Where did you get it? If it's used, perhaps someone special-ordered it black or painted it? Can you post a picture of it? Are you sure it's an NX, and not just a different one with an NX sticker? <shrug>
Old Oct 11, 2005 | 05:48 PM
Nitro Dave's Avatar
The purple ones is the olderstyle.About a year maybe 2 ago NX went to the Black ones.The only diffrence is the color.
Dave
Old Oct 12, 2005 | 10:24 AM
BlownF1's Avatar
Dave - Do you recall what the difference was between the 1st generation and the 2nd of the purple ones? I know I bought mine when they were first released, then I thought they came out with a "improved" version about a year later. I vaguely recall something about it being slightly shorter or something? Any clutch/motor differences? Just curious...thanks!
Old Oct 12, 2005 | 11:03 PM
Nitro Dave's Avatar
The only difference I can recall is color.
Ill check tommorow.
Dave
Old Oct 12, 2005 | 11:23 PM
JodyJ's Avatar
Ill check tommorow.
Dave
Also, I think the difference is the newer version will work with all nitrous bottle, including the NOS bottles where the older version doesn't.
Jody J.
Old Oct 13, 2005 | 11:47 AM
Nitro Dave's Avatar
OK according to Ricky at NX. The very first purple ones were tall.Then NX went to the short style purple ones and then took the color to black.
Dave
Old Oct 14, 2005 | 08:01 AM
BlownF1's Avatar
Cool, thanks for following up Dave!
BTW, not sure if I already said it, but the bottle valve you sent arrived super quick and solved my problem. Thanks!!!
Old Oct 14, 2005 | 08:47 AM
Nitro Dave's Avatar
No problem.
Thank You for your support.
Dave
Old Oct 14, 2005 | 12:06 PM
FatalZ28's Avatar
I'm glad they went to black. I didn't like the purple that much.
Old Oct 14, 2005 | 12:59 PM
JodyJ's Avatar
Brian,
What issue were you having the the bottle valve? I've been having some issues with the bottle opener having troubles opening, but closing is fine. I've adjusted the screw on the bottle opener, but sometimes it'll open and sometimes it won't, especially when you need it
I notice sometimes it takes some effort to manually open the valve with the regular handle installed.
Thanks,
Jody J.
Old Oct 14, 2005 | 01:19 PM
94Zpower's Avatar
Thanks for the info Guy's!!
Old Oct 14, 2005 | 01:56 PM
BlownF1's Avatar
Originally Posted by JodyJ
Brian,
Thanks,
Jody J.
LOL...that sucks, but then again I've never really "needed" it...
Actually, my problem was 2 fold...first the valve was leaking when fully closed, so I lost an entire bottle.
Second, like yours, mine was intermittently difficult to open.
As the problem presented itself, I tightened the clutch several times and eventually it was opening/closing the bottle too hard. This only made the problem worse and I'm sure having the clutch too tight to begin with is what led to both problems.
The new valve from Nitro Dave opens and closes 1000% better and smoother. It's the new 45degree valve and I allow it to overrun as little as possible...that reminds me, I should backoff my clutch a bit too.
Old Oct 14, 2005 | 02:04 PM
JodyJ's Avatar
Cool, thanks for the info I guess I'll e-mail Nitro Dave and get pricing on two valves. Was it easy/straight forward on replacing the valve?
Thanks,
Jody J.
Old Oct 14, 2005 | 02:15 PM
BlownF1's Avatar
It's a simple process...just unscrew the old one and screw in the new one. The problem is they are TIGHT! This is actually the second time I had to replace one. The first time we couldn't hold the bottle without it slipping, so we actually jacked up my car and put the bottle under the rear tire and brought most of the weight down on it to hold it, then the valve came off piece of cake...LOL! This time, I took two 2' long bar clamps and clamped them to the bottle and laid it down on the ground and sat on it...the bar clamps gave me much more leverage.
I'm sure you could just get Robert Wilson to hold the bottle while you turn the wrench!
