NOS bottle question
Old Dec 1, 2005 | 10:40 PM
walt355's Avatar
NOS bottle question
I have one of the old tall skinney 10 lb bottles NOS brand. It is dated 94 if that matters. Is there anything wrong with using this? I was going to try to round up one or two bottles. I have found some of these old botles reasonable on eaby and around. I dont want to have 2 diffrent bottle brackets. Any suggestions?
Old Dec 2, 2005 | 06:32 AM
Joe B's Avatar
Re: NOS bottle question
Up until just recently that's what I used exclusively.......as long as it's got the Hi-Flow valve which Im sure it does (but check anyway) a bottle's a bottle..........Im not sure what bottle brackets you have, but In my Vette Im still using the plastic ones that came in the kit for use with the old tall skinny NOS bottle, now being used on a bran new short fat NOS bottle......I just went to home depot and picked up some nice stainless bolts to bridge the gap.it looks alot better than it sounds , this way I can run both bottle styles......Joe
Old Dec 2, 2005 | 07:44 AM
LWillmann's Avatar
The only thing I can think of that would keep me from using one of the older style bottles is the valve. Assuming that it has a valve capable of flowing what you need it to, and assuming it's in good shape (does the valve ever wear out?) it should be fine.
Old Dec 2, 2005 | 08:54 AM
Here in NJ, some shops will not refill the bottles if the inspection date is expired. Technically, the bottle needs to be tested and recertified for pressure every 5 years.
Old Dec 2, 2005 | 09:12 AM
LWillmann's Avatar
Where can a person go to get that done?
Old Dec 2, 2005 | 09:20 AM
viperkiller's Avatar
one of our local fire dept. does that here.
Old Dec 2, 2005 | 11:04 AM
Joe B's Avatar
My local scuba shop pressure tests tanks, so Im guessing many do...they can also replace the seals if needed
Old Dec 2, 2005 | 01:58 PM
walt355's Avatar
The only place to fill them around here is about 30 minutes away in Bowling Green. They told me that it didnt matter about certification that they would fill them. I guess Ill try to round up a couple of more bottles and use these. Thanks fellas.
Old Dec 4, 2005 | 02:10 AM
dgZ's Avatar
dgZ
your local fire department should be able to certify it for you. my fathers a firefighter and he does his propane tanks and stuff there, check it out
Old Dec 4, 2005 | 09:35 AM
walt355's Avatar
OK thanks
Old Dec 4, 2005 | 12:14 PM
Welding supply shops will pressure test and stamp the bottles.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Speeds8erM-1
Aug 20, 2002 09:12 PM
Speeds8erM-1
Aug 15, 2002 10:07 PM
kandied91z
Aug 4, 2002 02:53 AM
