TNT, jets for 125 shot?
Old Sep 21, 2005 | 11:14 PM
94-3.4's Avatar
Can anyone clue me into what jets to run for a 125 shot on a TNT F2 plate setup? I only have the chart that shows 100 and 150. Thanks!
Old Oct 4, 2005 | 08:34 PM
Dan Parker '96's Avatar
Re: TNT, jets for 125 shot?
On my '96 Vette with LT4 heads, Hotcam, stock exhaust, 50psi fuel, 950psi N2O I found that with the TNT F1 setup that the supplied 75hp fuel jets (dual .018) and the supplied 100hp jets (dual .039) netted me a tick over 120RWHP (Dynojet). I was using the LT4 28lb. injectors at the time.
AFR was smooth around 12:1. N/A the AFR was about 12.8-12.9:1.
For comparison with the same setup as above (minus fuel/N2O jetting).. My initial "testing phase" of the TNT system used the 75hp fuel (.018) and 75hp N2O(.031). This combo netted 65RWHP at something below an AFR of 9.5:1
My point being... Make sure you are using a wideband O2 sensor and start conservatively. Too rich a mixture is unlikely to destroy your engine, too lean has a high probability.
Plus there's a lot you can play with to tune it "just right". Bottle pressure (provided you use a pressure switch) and fuel pressure are easy to adjust. Both can have a high impact on the end result.
Sorry I can't give you exact numbers for jetting.
Old Oct 4, 2005 | 11:11 PM
SJG3RD's Avatar
Fuel
Old Oct 4, 2005 | 11:14 PM
SJG3RD's Avatar
Fuel Nitrous
100hp 22 39
150hp 25 46
As far asI know TNT doesn't have 125hp jets, but I do not know that for sure. Those #'s are straight from the card from TNT.
LT14LIFE
Nov 15, 2015 06:22 PM
68camaroboltz
Oct 5, 2015 11:56 PM
Sep 18, 2015 03:46 PM
NewsBot
Sep 15, 2015 11:53 AM
damnyankee36
Sep 9, 2015 07:06 PM
