175 shot...whats needed?
Old Aug 17, 2005 | 12:35 AM
2FNFAST's Avatar
What all would need to be upgraded on an LT1 to safley run a 175 wet shot roughly twice a week on a daily driven car. The short block is about to be apart because it needs rings and I would like to go ahead and throw some forged 30 low compression pistons in (because I plan to run a S/C in the future). So far all I have is a hot cam kit and some EX Hardened push rods. Would this get me around 500 rwhp with a hot cam? Also I am thinking about the cold fusion kit..is this a good kit? Also what all would I need to safley spray a motor often? Window switch? purge? bottle warmer?
Old Aug 17, 2005 | 08:52 AM
Nitro Dave's Avatar
Re: 175 shot...whats needed?
If all you plan on spraying is a 175 shot other than the mods you already listed I would upgrade the fuel system.If you want a top quality system at a good price send me a pm.Ill see what I can do to get you Into a NX system.There alot better system than the one you are looking at.I suggest getting a window switch,NGK TR6 spark plugs,Nitrous pressure gauge,bottle heater and purge.You may look at NXs GENX2 package for all your accessories.It will save you money buying all the accessories that way.
Dave
Old Aug 17, 2005 | 11:59 AM
HarrisSpeedWorks's Avatar
The Cold Fusion kit is a very good kit. All of our Cold Fusion kits come with a lifetime warranty and a 100% customer satisfaction policy, if you don't think the kit is a "quality" kit we'll give you a refund.
You'll want some colder plugs; the NGK TR-6s are nice, along with a fuel pressure safety switch, bottle heater, and window switch. What kind of fuel system are you running? Let me know if you have any questions or if you are interested in a CFN kit shoot me a PM and I can work on the price for ya.
Thanks,
Matt
Old Aug 18, 2005 | 09:44 AM
roadtrip120's Avatar
200 SHOT IT, just kidding
Mine held, stock bottom end. Run some Tr-6's, pull some timing 1-2 stock tune, 2-3 for after market tune, if you cant pull tiimg better run straight race gas. But i would pull it out. I know guys that run if off the fuel rail but you might think about a fuel pump, or a stand alone fuel system. The good thing about the stand alone is, you can put race gas in there. The cost is $7.50 for one gallon of the good stuff, vs; $35.00 for four gallon that will mix in your tank. Plus the race gas only comes in when you are needing it, vs; using whats left over on the way home from the track.
Spend the money now on the safety stuff.. , Retune ,Pressure safety switch, gauge, stand alone fuel sys.
The cost is alot cheaper than , buying a new bottom end. IF you are going to do it do it as safe as you can make a 175 shot.
Old Aug 18, 2005 | 02:28 PM
whatsup's Avatar
Originally Posted by roadtrip120
The cost is $7.50 for one gallon of the good stuff.
HOLY $^%$...
Its 3.99/gl here for 110.
Parts Wanted
Mar 17, 2015 11:24 PM
nikolt1
Feb 27, 2015 09:10 PM
HectorM52
Parts Wanted
Feb 11, 2015 09:33 AM
NED4SPD
Sep 16, 2002 10:45 PM
mjcent922
Jul 27, 2002 12:42 PM
