nitrous cam
Old Aug 11, 2005 | 08:52 AM
blackz151's Avatar
nitrous cam
i am in the process of building a 355 for like a 250 shot. Now i am at the point of picking out a cam. witch cam should i use. i was looking at the nitrous cam from comp cams.
dur.
268/286
lift
.477/.490
and other ideas i am tryin to get the best cam so i dont have to change it down the road
Old Aug 11, 2005 | 05:06 PM
NVetro's Avatar
Re: nitrous cam
Problem with nitrous cams, and its been proven time and time agian with dyno charts on this board is they are GREAT with n2o, BUT when it comes to N/A, they will make less power and obviously dyno less then most people would like. Talk to Bret Bauer (SStrokerace), he can make a custom grind cam for ya, I went with him for my 383 setup. Shoot him a PM or something, you'll thank yourself later, he has a god brain to pick also
Old Aug 11, 2005 | 05:47 PM
Nitro Dave's Avatar
Re: nitrous cam
I second getting a custom grind cam.Off the shelf cams are ok.But for the best results a custom grind normaly complements your setup.I use Laser cams.Bill has always done a great job for us.
Dave
Old Aug 11, 2005 | 10:34 PM
slomarao's Avatar
Re: nitrous cam
How much are you going to use n20? If you plan on using it whenever you race you should get a nitrous grind. Otherwise you should get a NA cam and keep it on 114.
Old Aug 11, 2005 | 11:19 PM
blackz151's Avatar
Re: nitrous cam
i am gonna use it when i go to the track like twice a month and like when i playin around with some imports around here
Old Aug 12, 2005 | 08:01 AM
NVetro's Avatar
Re: nitrous cam
Yea, then def get a custom grind. They arn't much more $$ either.
camaroguy50613
May 27, 2016 09:00 AM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
MadMav
May 25, 2015 09:35 PM
bandit383lt4
Dec 21, 2014 09:12 PM
