Hidden N20 Setup
Re: Hidden N20 Setup
same war different sides...best i can say to you, is let them see what they want to see...if they want you to pull a bottle out of the car so they feel your not on the bottle...then pull a bottle out of the car for them.
probably have to go with a dry system to bring down the amount of lines to conceal. you could put that sneeky pete system in the area where the spare tire tools are, probably want like a 2lb bottle instead of the 10oz bottle it comes with. alsoif you don't have traction control I heard someone say they used the box for the system and put the solenoids in and wired the on switch to where the TCS swiitch is on the dash above the radio.
Im considering N20 but i want a good place to hide it. My buddy has a zex wet system which i like....i might try to hide that underneath the intake elbow and try to hide the lines as best as possible. Any other suggestions? or places?
Here is a reference guide to completely hidding your N20 set up: http://www.geocities.com/MotorCity/1920/nos.html
I think the best hidden N20 setup (dry kit) is mounting the bottle behind the bumper (where the bumper support normally is) and if it a dry kit just run the line from the bottle to solenoid (put this in a unnoticiable area) and then put the nozzle under the intake elbow and go through and slide a rubber hose over the braided stainless steel N20 line. I have seen this done but not in a F-body, so I don't know if your going to have enough clearance behind the bumper for sure, but it would be worth a shot.. only negative is that you are obviously going to have to take remove the rear bumper cover and take the bottle out when you are not planning on racing for obvious safety reasons..
iv seen a monifold where a guy pretty much put everything under it (wet direct port drilled in the runners under the intake) and at the back of the manifold he tapped out 2 holes and put AN fitting on for mounthing the nitrous and fuel lines ran the lines under the car and had the bottle under 2 fake 10" subs in the back of the car....... its weird i know but it worked donno if you can do it to a LT1 intake though
