All Fordged...How much spray?
Old Sep 18, 2005 | 10:45 AM
FMFRacing88's Avatar
Hey I have an 88 Firebird with a 355 HSR with AFR 195s....Eagle Fordged crankshaft, Eagle 6" fordged H beams, and JE fordged flattop pistons.
Was just wondering how much nitrous I could use safely with this setup assuming I have all the safety acceroires and everything is tuned right. I was thinking to go with a wet shot..Also should I go dual stage??
Any suggestions would be helpful..Thanks
Old Sep 18, 2005 | 08:53 PM
rskrause's Avatar
Moderator
Re: All Fordged...How much spray?
With pump fuel, your good pistons and decent crank and rods won't make a lot of difference. No parts will stand up to very much heavy detonation, which is what will happen with pump gas and more than an ~150hp nitrous shot. Of course, part of the answer depends on what you mean by "stand up to". Once? A few times? For how long? IOW, it's not just how much, it's how long as well. Again, with pump gas an a small block, I'd limit it to ~150hp. IF you can use high octane race fuel, a 250 shot is certianlywithin the realm of the possible. Maybe a bit more, again depending on the issue of "for how long". Of course, an adequate fuel system, cold plugs, retarded timing, proper ring gaps, etc. all become more and more important as the nitrous dose increases.
Rich
Old Sep 18, 2005 | 09:46 PM
Was the engine assembled knowing that it would be running nitrous? Are they "nitrous" pistons.... often modified for greater crown strength, upper oilers, dropped ring pack location, etc? Were the rings gapped for the extreme temperatures you get with nitrous?
Old Sep 19, 2005 | 07:20 AM
rskrause's Avatar
Moderator
Yeah, Fred's post reminded me of something I thought of after I posted. JE makes a number of different flat tops. Some are very light and DEFINITELY not suited for nitrous use. Ditto for the wrist pins, you want to avoid light weight pins with N2O. There are a lot of details that can make a difference.
Rich
Old Sep 19, 2005 | 04:28 PM
The motor was built to be a stong N/A motor but with nitrous in mind for later....I am thinking about running a single stage NX kit with a 150 shot....the car is my daily driver so it will only see the spray at the track prob twice a month.
Old Sep 19, 2005 | 05:16 PM
rskrause's Avatar
Moderator
If it has the right JE piston (not the light weight model) I'd say "go for it"!
Rich
Old Sep 19, 2005 | 06:38 PM
Sorry they are actually SRP pistons which i guess are the same as JE..I bought the whole rotating assembly from CNC-Motorsports.com and it just says fordged aluminum...how do i know if they are lightweight or not?
Old Sep 19, 2005 | 08:48 PM
rskrause's Avatar
Moderator
You should have gotten an invoice/reciept with the part numbers. Is the RA already installed? If not, there should be a number cast on the piston that you could call JE/SRP with to find out what you have.
Rich
Old Sep 19, 2005 | 09:02 PM
Loadre's Avatar
I run a 200 shot through a single nozzle on Food City pump gas with zero detonation.
Jeff1904
Jun 5, 2016 05:00 PM
damnyankee36
Sep 9, 2015 07:06 PM
95z28man7
N2O Tech
Aug 16, 2015 10:58 AM
30th Anniv Z28
Aug 1, 2015 10:39 AM
RX Speed Works
Jul 24, 2015 02:25 PM
