Almost went 11's..
Old Nov 21, 2005 | 10:03 PM
cpt_bimes's Avatar
Almost went 11's..
Well guys..went to the track on sunday and i surprised myself and every single LS1 guy out there...
I basically ran an 11 with these mods: stock manifolds, stock tune, full weight (including spare), Yank SS3600, 3.73's, Mt ET street radials Bogart Skinnies, and a NX "fat" 75 wet shot, stock suspension except relocation brackets.
I got on the brakes hard on that run way before the 1/4 mark because i thought i heard something bad happening so just to be safe i let out.
I like the wheel pulling action myself
http://www.ncoutlaws.com/videos/1205.wmv
Old Nov 21, 2005 | 10:06 PM
Nitro Dave's Avatar
Re: Almost went 11's..
Wow,
Nice job.
Dave
Old Nov 21, 2005 | 10:09 PM
cpt_bimes's Avatar
^me and my buddy called "the outlet" on thurs. to ask you some questions about which nx nozzle i should get. Shark or pirrahna. I commend your customer support along with NX's.
Old Nov 21, 2005 | 10:17 PM
Nitro Dave's Avatar
Oh I remember. That was me yall talked to. So did the shark work good.
Dave
Old Nov 21, 2005 | 10:21 PM
cpt_bimes's Avatar
yessir...felt reaalll good
we played around on the street a bit...my nitto streets were not happy
And boy did it feel good on the track..i've never ridden in anything down the track that cut a 1.59 60 ft....it shot out of the hole like a raped ape.
Old Nov 22, 2005 | 04:49 PM
chevy94c's Avatar
Nice video
Old Nov 26, 2005 | 09:02 PM
AutoRoc's Avatar
Easy 11.60's next time out! Nice work. PILL IT UP!!!
Old Nov 27, 2005 | 12:04 PM
Cmr0z28's Avatar
Very nice..what's your launching technique?
Old Nov 27, 2005 | 01:20 PM
2000GTP's Avatar
Wow, very nice times. How is the 3600 stall converter working on the streets? I was planning on doing a higher stall converter next spring along with the trans. rebuild, but I am still debating on what stall to go with. I was also planning on installing a nitrous kit next spring as well, but am still debating on the NX kit or the TNT kit.. But this is all assuming my motor passes a compression test and maybe a cylinder leakdown test first to make sure it is healthy. Anyways, nice times once again.
Old Nov 27, 2005 | 08:28 PM
cpt_bimes's Avatar
I don't go by RPM's really..I stall the car up till i feel the back "lift" then i back off a bit and let her settle down some. I try not to launch the car with the suspension extremely loaded.
I love that thing. The 3.73's tamed it down a bit. It was stalling way higher with the stock 3.23. I've got the transmission locking up around 40mph so that works out good in town. It makes it where i'm at ~1500. whereas i'd be at ~2300 unlocked.
Old Nov 28, 2005 | 08:45 AM
2000GTP's Avatar
Are you still working off of the stock 10-bolt?
Old Nov 28, 2005 | 09:01 PM
cpt_bimes's Avatar
oh yeah...and i have no fear of breaking it.
Old Nov 29, 2005 | 02:55 AM
96ta(nick)'s Avatar
I wish i could pull 60s like that.. I could only manage a 1.70 with my 6speed.
Old Dec 2, 2005 | 05:44 AM
BD380's Avatar
Do you have a window switch? If so, what RPM do you activate the spray?
Old Dec 6, 2005 | 01:11 PM
cpt_bimes's Avatar
no window switch..just the NX TPS activation switch
IllusionalTA
Jun 3, 2006 10:13 AM
WS6pete
Apr 23, 2004 02:25 AM
importeater
Mar 24, 2004 02:51 PM
Punisha69
Dec 27, 2002 01:52 PM
