dry n20 jets
Old Nov 30, 2005 | 12:44 PM
realslow94z28's Avatar
dry n20 jets
what are the jet sizes for a dry kit (75hp-125hp).
Old Nov 30, 2005 | 01:36 PM
LWillmann's Avatar
Re: dry n20 jets
.041 I think is 75 HP
.046-.047 is 100 HP
and .052 I think is 125 HP.
Old Nov 30, 2005 | 07:24 PM
Re: dry n20 jets
thanks for the info.
Old Nov 30, 2005 | 09:46 PM
streetbad's Avatar
Re: dry n20 jets
From OneFlyin95z28 45N+67F=80hp
49N+65F=100hp
72N+54F=175hp
Old Dec 1, 2005 | 07:36 AM
LWillmann's Avatar
Re: dry n20 jets
49N+65F=100hp
72N+54F=175hp
Granted this guy wanted to know about just they nitrous part, but the fuel jet sizes you mentioned make no sense. From this, as you step up in nitrous, you step down in fuel. This must be for a carb setup or something because of how large the fuel jets are.
Just odd that as he steps up in nitrous jet, he steps down in fuel. I would think that would make it leaner as he went.
Old Dec 1, 2005 | 04:19 PM
streetbad's Avatar
Re: dry n20 jets
I am glad you mentioned this. The "fuel" jets mentioned are for the Nos #5176 kit which has a Tee'd in nitrous regulator to raise fuel pressure via the fuel pressure regulator. By putting progressively SMALLER jets in the line which feeds the nitrous regulator -to fuel pressure regulator - fuel pressure is INCREASED.
Old Dec 2, 2005 | 07:42 AM
LWillmann's Avatar
Re: dry n20 jets
Thanks for the clarification!
I didn't realize that NOS wet kits used the tee'd regulator to boost fuel pressure. I ASSumed that was only for the dry kits to compensate for the nitrous.
Old Dec 2, 2005 | 06:55 PM
Joe B's Avatar
Re: dry n20 jets
Nah your right, It is just the dry kit that has the pressure tee, the 5176 is a dry kit.......the whole "fuel jet" thing on a dry kit is kinda confusing, they should just call them pressure jetts or something
Old Dec 2, 2005 | 10:09 PM
Re: dry n20 jets
Did you read the original question? He is asking for the jet sizes for a DRY N2O system? The NOS 5176 kit is a DRY kit. NOS does not use the "tee'd regulator" for their wet kits.
Old Dec 3, 2005 | 10:23 PM
LWillmann's Avatar
Re: dry n20 jets
I read the original question, but had a major brain fart and forgot about the pressure regulator. I also didn't research to find that the 5176 kit is a dry kit.
Sorry.
Old Dec 4, 2005 | 12:23 AM
Mike Comp T/A #57's Avatar
Re: dry n20 jets
My NOS #5176 dry nitrous system came with 67N/42F in 1996.
I believe Edelbrock uses the same size jets for their dry kit.
GREEN3112
Feb 10, 2019 09:19 PM
Jeff1904
Jun 5, 2016 05:00 PM
Cbr02
Aug 24, 2015 07:12 AM
Devinfoote87
Jul 30, 2015 09:54 AM
Boss002
Jul 24, 2015 10:47 AM
