Could I use this switch...
On my '97 Z there's a switch that trips with the clutch pedal is released. The pedal basically rests on it while the clutch is engaged. Now, do you guys think it's a good/bad idea to wire that switch, along with a WOT switch, to deactivate the spray when you press the clutch in? That way it shuts off right before the shift...and once you're up a gear and back on the gas. Maybe?
I don't have a kit yet...still waiting for a decent priced one...TIA
Re: Could I use this switch...
If you power shift, this might be a good idea as it would keep the nitrous from spraying during the shift. If you speedshift then it probably won't make that big a difference since you're coming off the gas during the shift anyway.
Y2K2Sierra
Oct 27, 2004 04:07 PM
Y2K2Sierra
West South Central
Oct 27, 2004 04:05 PM
