How to run the wires??
Old Nov 9, 2005 | 10:55 AM
sunsetorangess's Avatar
I need to run some wires from the engine bay into the cab for my nitrous kit. Is there a existing hole in the firewall or do i have to run it under the car??
Old Nov 9, 2005 | 11:08 AM
NXRicky's Avatar
Re: How to run the wires??
Under the computer on passenger side./
Ricky
Old Nov 9, 2005 | 12:32 PM
BlownF1's Avatar
Ricky
Exactly...just be sure to put the wires THROUGH the grommet located behind the computer. For some strange reason people seem to just push it out of the way and run the wires through the hole next to it. I've seen it done with wires and nitrous lines...not a good idea and they'll eventually get damaged.
Old Nov 9, 2005 | 02:14 PM
LWillmann's Avatar
There's plenty of room in that grommet if you get creative when stretching it too.
I have a 1/0 Power cable for my stereo system running through it, in addition to some other wiring for my fuel pressure gauge and nitrous system and ignition box.
If you have to, use a wire coathanger to stretch it so you can run whatever wire through there.
Old Nov 22, 2005 | 09:08 AM
my94blackz's Avatar
There was a hole on the driver side of mine, ive got about 6-7 wires coming threw it. Its right under the steering colum.
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
rs91
Aug 13, 2002 12:09 PM
Mad_Ice
Jul 29, 2002 09:44 PM
Wilson
Jul 21, 2002 04:58 PM
