nos stage 2 question?
i have the simple set up a 150 shot but i keep going through drive shafts so i was thinking of going with the stage 2 so i can shot 50 and the 100 a lil later ...my questin is how expensive is this to switch and what do i need to do this .....thanks
Re: nos stage 2 question?
A two stage set up is a good idea. Do you already have a window switch? If you do you can use another to turn on the second stage or you could use a time delay timer. You'll need another nozzle(s) & Solenoids, along with some more line to tie those components together. You'll also need some misc. stuff, like Ys or T fittings and jets. If you have any questions or you'd like a quote let us know.
Thanks,
Matt
Thanks,
Matt
yeah, basically as stated, you'll need something to trigger it on after a predeterimined amount of time/rpm and basically a full second nitrous kit. you can use the same bottle, but you'll need everythihng else after that basically.
i use a window switch (MSD-8969) , and then a secondary rpm module(MSD-8950)
basically, when you arm the system, the window switch power line is wired to a relay, that relay gives power to the solenoid(s) and gives power to the 2nd rpm switch. i put an inline toggle switch on mine, dont wanna spray it if i dont have to, only need to win, not slaughter them
this is the cheapest way i have found using msd stuff, 90 for the window switch and like 60 for the 2nd rpm switch. but that is the electronics of it anyways.
you'll need nozzles, jets, line, noids, Y for the n2o line. and i am not positive about this, but i believe the most you can spray on a -4 is roughly a 125-150 shot. just for future reference if you decide to go bigger.
also might want to invest in a denny's nitrous drive shaft..may be a cheaper investment all together.
importkiller94
Jan 17, 2015 09:03 PM
