175-200 shot, 255lph enough?
Old Nov 20, 2005 | 10:55 PM
94-3.4's Avatar
My current setup is a stock bottom end lt1, built trans, 2800 stall, etc etc and a 100 shot (tnt w/o plate) and it has been working great (turning high to mid 11's at high altitude. I want to step up to a progressive 175-200 with the new FJO system. I am running a 255lph racectronix fuel pump for fuel and that is the only thing I have changed with the fuel system. Will the 255 be enough to support the type of nitrous shot I am looking to spray? Should I consider going to a dual intake setup? I know fuel is #1 important and don't want to risk anything going astray.
Old Nov 21, 2005 | 12:30 AM
Cmr0z28's Avatar
Re: 175-200 shot, 255lph enough?
It will handle it just fine. A friend of mine had a built solid roller 383 w/high compression and a 200+ shot. His fuel system consisted of bigger injectors and a Racetronix 255lph pump. He didn't even need the Racetronix harness, his fuel pressure was perfect.
Old Nov 21, 2005 | 08:22 AM
HarrisSpeedWorks's Avatar
You should be okay with the single pump Racetronix kit.
Matt
Old Nov 21, 2005 | 10:19 PM
Nitro Dave's Avatar
Go for it. That will support it fine. Make sure you run good gas.
Dave
Old Nov 21, 2005 | 10:46 PM
94-3.4's Avatar
Sweeeet, thanks for the info gentlemen!
Formula Steve
Sep 19, 2023 08:31 AM
68camaroboltz
Oct 5, 2015 11:56 PM
Sep 18, 2015 03:46 PM
NewsBot
Sep 15, 2015 11:53 AM
damnyankee36
Sep 9, 2015 07:06 PM
