quick Procharger question
Old Nov 12, 2003 | 10:32 PM
RacinLT1's Avatar
Does anyone for a fact if the F1R will fit in the LT1 barckets? I dont remember seeing if it did or did not...
i am aware of the block and frame clearance issues,and these will be addressed in the near future. This is basically going to be an all out drag setup,with extremely limited street use.
Old Nov 12, 2003 | 11:02 PM
GhostZ's Avatar
http://web.camaross.com/forums/showt...hreadid=111058
"I looked into the F1R, to the point of ordering it and returning it for an F1. I'm sure it could be done, but it would be difficult to fit on a 4th gen with all the accessories. Looking at it and making some measurements made that obvious. When I did some hard thinking about it, I realized it wasn't worth the trouble. The F1 flows 1525cfm. This is more than any LT1 I am ever going to build for my street/strip car can use. Maxing out out this blower would be good for 900rwhp at least. My goal for the new setup is in the range of 900rwhp. But ~150hp will be supplied by the N2O and the F1 is easily capable of 750rwhp." -RSKrause
Old Nov 12, 2003 | 11:15 PM
RacinLT1's Avatar
fully aware of that thread,guess i didnt interperit it well enough.
Rich,hopefully you will see this....where did you order the F1R from?
Old Nov 13, 2003 | 06:21 AM
IDOXLR8's Avatar
I currently own a F1 and in order to get that to fit properly I had to grind away at the block. ATI does not make a bracket that will fit F1-R in an LT1. You will have to custom make a bracket. Expect to hack up the inside of your engine compartment to get that bad boy to fit.
Old Nov 13, 2003 | 09:04 PM
RacinLT1's Avatar
Thanks for the info,thats what i needed to know.
im gonna see how my buddies 3rd gen race bracket for the F1R and see what happens,the new hood im running should give me the room.
D1SC383LT4
Jan 1, 2016 01:56 PM
94Form
Feb 10, 2015 11:23 PM
SmokinZ28lt1
Feb 5, 2015 04:33 AM
SpeedJunkee
Jan 27, 2015 10:02 PM
D1SC383LT4
Jan 26, 2015 01:41 PM
