Mounting a BIG intercooler on a 4th gen?
Old Oct 3, 2003 | 01:03 PM
rskrause's Avatar
Moderator
Even with the water, my IAT's are just too high. I am going to do an intercooler this winter but need a BIG one to complement the ATI F1 I am using. Presently, it makes 17psi of boost and I plan to crank it up next year.
Anyone put a big IC on a 4th gen? What are the dimensions of the IC and how/where is it mounted?
Thanks for any hints or help you can provide.
Rich Krause
Old Oct 3, 2003 | 01:17 PM
Guido's Avatar
Here is a rather large one:
http://www.ls1tech.com/threads/showf...5&o=31&fpart=1
Old Oct 3, 2003 | 01:29 PM
MEAN LT1's Avatar
Basically, it looks like two three-core intercoolers from ATI.
Old Oct 3, 2003 | 02:02 PM
Birdie2000's Avatar
Re: Mounting a BIG intercooler on a 4th gen?
Good lord Rich, does it ever end?
Old Oct 3, 2003 | 02:57 PM
aram's Avatar
air-air or air-water? It might be easier to with an air-water as you would have more mounting possibilities... even though they are a lot more complicated.
Old Oct 3, 2003 | 04:50 PM
1st and goal's Avatar
Brady's got a big bastard on his twin turbo Z.
The link is http://turbocharged.net/twinturbo/Installation7/
Uncle Marc
Old Oct 3, 2003 | 10:31 PM
mongse_1's Avatar
Yep, it may be time for air-to-water.
Old Oct 3, 2003 | 11:31 PM
rskrause's Avatar
Moderator
Thanks for the links, but does anyone know the source for the IC's pictured? I am looking for brand names/model numbers, etc.
Rich Krause
Old Oct 3, 2003 | 11:43 PM
Brady's Avatar
Rich, I think you should explain what you are trying to improve exactly... Are your IAT's too high just cruising around, or are they too high during a pass/dyno run?
With my twin setup and the 6-core intercooler, the IAT's stayed nice and low all the time.. But I think they IAT's would be be reasonable with a much smaller air/air intercooler for normal driving and during a pass I think the IAT's could be lower if I used an air/water intercooler..
If your IAT's are livable during normal driving, you should think long and hard about an air/water setup.. Set it up to Kick the water pump on using a hobb's switch so you have a nice reserve of cold water to cool the intake charge when you make a pass or feel the urge for some spirited driving..
I know my next intercooler will be air/water..
good luck
...Brady
Old Oct 4, 2003 | 06:44 AM
rskrause's Avatar
Moderator
Brady: good questions! I really have never been concerned with IAT except at WOT, should I be? The air-air is clearly less efficient, but the simplicity appeals to me. Everything else is already so complicated on my combo, that I hesitate to add another complex system.
Rich Krause
Old Oct 4, 2003 | 11:49 AM
96 WS6's Avatar
What are using to control your alky pump? A WOT switch? Hobbs switch? If so you might consider investing in a progressive pump controller... it will allow you to give yourself enough alky to cool your air significantly whether it's low boost or high boost. That's what I would consider first since you already have the kit on your car and it would just be a simple wiring matter. Check out www.alkycontrol.com, he's from Florida and he makes nice controllers and alky kits. I believe it's 200 for a progressive and you can set intial pump speed, initial turn-on point (wired to the MAP) and final ramp gain of the pump voltage. There is a video of him making a run to 26 psi in his TTA on pump gas with no knock until the shift. Granted it is intercooled but it's a stock TTA intercooler on 26 psi so it's not really doing much for the cool air cause.
Old Oct 6, 2003 | 06:04 AM
IDOXLR8's Avatar
Rskrause
I am currently working with Griffin Intercoolers on a front mount for my car. Are you planning on running the inlet and outlet on same side? You want to check this out :
Old Oct 6, 2003 | 12:16 PM
sleeperz28's Avatar
Rich I got my intercooler from a local that had it on a race supra. This thing is massive, the measurements of the core; 4.5" thick 25" long and 18" tall. Im not sure of the flow charactoristics but i have never had air temp issues. On 19psi on the data logger my temps usually start at about ambient or a few degrees more. Then by the end of a 1/4 mile pass the heat generated nets about a 12 degree increase. I do know it was from spearco and about a $1600 intercooler. Check out my site you can see how its mounted. As for room you cant get much thicker and I dont see why going longer or wider would make a difference with the way the front is cut up.
Old Oct 6, 2003 | 04:47 PM
Secret Formula's Avatar
http://www.bmrfabrication.com/Buildup5.htm
Old Oct 6, 2003 | 06:13 PM
JordonMusser's Avatar
West South Central Moderator / Special Guest
Rich-
you will find that those "big" ICs are all custom.
I can get you a custom spearco IC for a good price if you are interested.
I am ordering 2 1500cfm ICs just like the one in my car next week, and can get you in on the deal if you like(custom bar/plate spearco)
