Boost is falling off.
Old Nov 3, 2003 | 02:58 PM
NiteRyda's Avatar
When i was racing my car at the track friday night, it pulls like crazy in first gear but in second and the rest of the gears it stops pulling hard at about 5000 rpms and 5.4 psi of boost and it does it every time. It is a 8psi procharger. In first gear the boost reads about 8p.s.i at 5900 rpms. And also im getting a Engine Code 11 on my OBD-1 PCM conversion.
Thank's to everyone help in advance.
Old Nov 3, 2003 | 09:24 PM
sleeperz28's Avatar
First will pull no matter what so scratch that. This is recent? Well have you done any diagnostics? Clogged air filter....intake tube collapsing....belt slipping....blow-off valve sticking...
Old Nov 4, 2003 | 10:12 AM
mongse_1's Avatar
That's what I'd think. The Prochargers had a bad habit of doing that, especially at the elbow on the bottom of the charger. Seen it happen on several different cars on the dyno.
Old Nov 4, 2003 | 11:00 AM
NiteRyda's Avatar
Intake tube
What's the fix of the intake tube, how can u tell if it's failing.
Old Nov 4, 2003 | 11:27 AM
mongse_1's Avatar
Next time it's on a dyno. Have someone watch the tubing, especially the rubber elbows. It's pretty obvious when it happens.
To fix it, you can either fab up a metal elbow or buy a rubber cobrahead fitting from a semi parts store.
http://shop.airflowonline.com/Mercha...ct_Code=90CB30
Here's some pictures of the one I had for my Procharger.
http://www.quarter-mile.net/03buildu...obrahead01.jpg
http://www.quarter-mile.net/03buildu...obrahead02.jpg
http://www.quarter-mile.net/03buildu...obrahead03.jpg
PopoFormula
Oct 12, 2015 04:19 PM
Mikes 1994 z28
Oct 10, 2015 07:55 AM
alliance12364
Sep 23, 2015 12:40 PM
Matt Dreessen
Sep 9, 2015 09:58 PM
