boost and rpm
hey everybody . . .with a powerdyne 4.5 when does the boost kick in??at 3000 rpms right??is there a way to bump up the rpm till the boost kicks in?? because i want to get one for my daily driver . . i guess if i cant bump up the rpm ill just have to baby my car and not go over 3 grand . . superchargers are only stressful on the car if its useing boost right?? thanks for checking out my post
With most centrifugal superchargers you will only see the boost under WOT. Under normal driving conditions your engine will be under vacuum just like a N/A engine and the bypass valve will bleed off the boost. It makes driveability great.
RUENUF
Mar 13, 2016 03:37 PM
Aug 7, 2015 01:26 PM
Henson071
Aug 4, 2015 09:32 AM
