Turbo update
Old Nov 11, 2003 | 10:58 PM
JordonMusser's Avatar
West South Central Moderator / Special Guest
Turbo update
Ok, sorry its been so long. I have had the flu, and been crazy busy.
Anyhow, car has been running for a little over a week now, the turbo system worked out perfect, however I have a miss i CANNOT find. I am going to replace all the plugs and wires (even tho the wires only have 2k miles on them, and plugs about 50miles). I already tried another opti.
blah!
Old Nov 11, 2003 | 11:32 PM
GhostZ's Avatar
Holla!
How much boost are you running with it now? Still the T76?
Old Nov 11, 2003 | 11:50 PM
PTE88mm and 20+ psi
however, i cant get to that point(20+psi) when it wont even idle with out missing
ordering new wires and plugs as we speak. if it still misses, I am gonna jump off a bridge.
Old Nov 12, 2003 | 12:09 AM
GhostZ's Avatar
I might be getting in contact with you this Spring if you still plan on making turbo kits.
Good luck on the miss and I can't wait to see the 4 digit dyno and track times.
Old Nov 12, 2003 | 12:27 AM
Van's Avatar
Van
Jordon,
I noticed that you were selling your auto x susension set up.. Are you putting something more strip oriented together? Should be interesting....
BTW thanks again for the IC hook up...... Can't wait till it gets here! I'll be hitting you up for some install tips, IE keeping the airflow to the radiator.....
Rob
Old Nov 12, 2003 | 07:47 AM
mongse_1's Avatar
If you do jump off that bridge, just send you car along with my intercooler. I'll take care of it.
Old Nov 12, 2003 | 08:06 AM
got_hp?'s Avatar
start her up at night and look under the hood in the dark.
i have new plugs/wires, but still had a miss, and i found out two wires are arcing, by watching them at night.
btw, jordan......werent you opening up a website and doing custom work? what happened to that?
Old Nov 12, 2003 | 10:09 AM
yea, already did the "at night" trick.. no dice. www.musserracing.com
Van-
I am not selling my suspension, I was pondering an upgrade to koni DAs
Old Nov 12, 2003 | 10:19 AM
got_hp?'s Avatar
thanks jordon.........i figured you would already have checked that..........but sometimes we all overlook the easy stuff.
Old Nov 12, 2003 | 08:48 PM
383WS6's Avatar
PTE88mm and 20+ psi
wait a minute... you gotta build my turbo kit before you go jumping off of bridges... lol
Old Nov 12, 2003 | 09:41 PM
well, I sorted out the miss! man does she pull HARD.
I am only running 8psi, and didn't expect much.. because my heads aren't very good.. but it feels very strong.
Might try to hit the track to get some base lines this saturday.
Old Nov 12, 2003 | 09:45 PM
got_hp?'s Avatar
what was it?
today i found one of my plugs slightly loose!!!
Old Nov 12, 2003 | 10:03 PM
couple of things, thats what made it so tough to find!
Old Nov 12, 2003 | 10:15 PM
got_hp?'s Avatar
hehe......"couple of things"........is that as specific as it gets? haha
Old Nov 12, 2003 | 10:33 PM
What you can do with a $80K video camera
http://www.fastblackcar.com/camaro/t...8/thermalpics/
notice how cool the turbo blanket keeps things.
Also, you can see how my drivers side header is very uneven in temp.. found a vacuum leak, its all even now!
