Pics. of Procharged 454 in my 80 Z28
Old Nov 7, 2003 | 05:40 AM
JamesTKirk41's Avatar
Here are some pics of my Procharged 454 80 Z28. Anyone thinking of a a Procharged BBC in a 2nd. Gen take notice of the hole in the hood for clearance.
Paint is next.
http://community.webshots.com/user/jamestkirk41
Old Nov 7, 2003 | 07:50 AM
MEAN LT1's Avatar
Did that 454 block come out of a 90-92 SS truck?. Looks like it did, looking good.
Old Nov 7, 2003 | 10:33 AM
andol469's Avatar
Looks good.
Old Nov 7, 2003 | 10:42 AM
IDOXLR8's Avatar
Looks good What model blower are you running?
95 Silver TA's Avatar
Looks great....What are you using for cooling? Water injection? What about a Bypass valve?
Is this gonna be a strip car only or both Street and Strip?
What are your HP goals?
Inquiring Minds want to know
Thx,
Claude
Old Nov 7, 2003 | 01:19 PM
T/A lt1's Avatar
What trim blower is it? We have a D3R and also a D3M. They make some sick power on a BBC. We made 1150hp on the engine dyno with a 512ci. and the D3M last year.The setup is in a 4400lb 1967 Impala and runs 9.60's@142mph with the D3R. The carb acts as an intercooler on these setups so you can get away with 12-14psi w/o detonation as long as you don't have too much compression and have enough fuel which is the hard part with these blowthru carb setups believe me I know. Goodluck tuning one of these badboys is not easy. Later
Old Nov 7, 2003 | 02:46 PM
The motor is a 454 HO Gen V. The Blower is an ATI P1-SC procharger huffing 10 psi. My static compression is 8.75 to 1 with iron heads. I've been running on 93 octane fuel and do not have a boost retard or an intercooler. My current timing in probably way conservative at approximately 26 to 28 deg total. Plugs look slightly rich (which is good for me cause I would rather give up a little bit and keep it running). The carb was a 850 Holley mech. but now has a Proform main body to eliminate the choke tower. Jetting is 84 primary and 95 secondary. Fuel system is an Aeromotive pump and boost referenced reg. with 1/2" supply and 3/8" return lines. TH400 tranny and a Ford 9" rear w/ 3.42 gears. It is definately intended for the street.
Old Nov 7, 2003 | 04:00 PM
Sounds Sweet!!
How much HP are you looking to put down?
And I did not see anything in there about a By Pass Valve....Is there a reason why you are not running one?
Thx,
Claude
Old Nov 10, 2003 | 06:07 AM
Motor was 425hp stock and I was shooting for 625 with the blower. I am not running a bypass valve. What benefits would I see by doing so?
Old Nov 11, 2003 | 07:35 AM
I would assume that the benefits with a bypass valve would be the same for a Fuel Injected Car when let off the loud pedal, the air would vent to atomsphere and not fight against the blower impeller and carb blades/flaps. But Mabee a Blown Carb set up is different.....
Hopefully someone will jump in and shed some light on if its necessary or not with a carb car.
Thx,
Claude
D1SC383LT4
Jan 1, 2016 01:56 PM
SmokinZ28lt1
Feb 5, 2015 04:33 AM
SpeedJunkee
Jan 27, 2015 10:02 PM
D1SC383LT4
Jan 26, 2015 01:41 PM
