Procharger and head\cam selection
I bought a p600b 9 psi setup and i need advice on head selection.
I have a set of pocket ported gasket matched LT4's, and a set of ported LT's...LT1's flow 252 cfm and 191cfm at .600 with 1.94-1.50 Manley's...
Which heads should i use? I'm putting in a set of forged pistons for 9:1 compression and i also need a cam recommendation.
I called ATI, they weren't much help.....I figured you experienced blower guy's would know. Thanks for any help.
I'd get some flow number on the LT4's to see which is better. Absent that, I'd make a guess that the fully ported LT1 heads will be better.
Either of the following two cams works for 90%+ of centrifugal LT1 cars. Which to pick depends on how high you want to rev. The bigger cam requires very stiff valve springs and definitely upgraded pushrods and good quality rockers. The smaller cam can get away with quite a bit less spring and probably stock pushrods.
CC XE lobes #3190/3192 on a 114 LSA and a 114 intake center line. 214/224 @ 0.050" .530/.567"
CC XE lobes #3192/3196 on a 114 or 116 LSA with an intake center line of 112 degrees. 224/236 @ 0.050" .567/.585"
Rich Krause
Rich Krause
Originally posted by Grover
Rich,
What are the RPM differences between the two cams that you listed?
Rich,
Rich Krause
Sorry to intrude with a question for Rich but it goes along with the topic. I am running AFR 190s and just bought the smaller cam you were talking about. You mentioned using 977 springs. My AFRs are cut for a 1.530" diameter spring and looking at the Comp catalog saw the 929 spring which has a little more pressure and a recommended max lift of 0.650". Would these work well if I used 1.6 rockers?
Thanks guys
Thanks guys
Thanks for the help Rich, I would like to run peak power at 6000 or so. I will be using stock rods and a Scat 9000 series crank and forged pistons. ARP main studs (a little insurance) and rod bolts...It will be fully balanced and should live on 9 psi....
Just wasn't sure which head to run, the larger runners and valves,or the ported LT1's with flow #'s...I would expect the LT4's intake flow is the same, but the LT1's are bettor on the exhaust. This is an M6 car that is mostly street driven by the way.
Thanks for the cam recommendation's.
Originally posted by Rival
the 114 lsa will give you better driveability, easier to tune, and it is much better for a blower setup. It will not lope as much because the overlap will be less. the 224/236 is a great cam lots of people use it.
Rich Krause
Thanks guys
Thanks guys
Rich Krause
armedtrigger
Feb 24, 2015 08:30 PM
F(ast)-body
Feb 26, 2003 09:05 AM
