Turbo questions
Old Oct 23, 2003 | 07:11 PM
RobZ's Avatar
Turbo questions
I want to do a single,but im not able to decide on what type of tubing for the turbo manifold.I have in mind a 3/8 thick flange with 1 3/4 diamiter tubes.What would be best?Would the type of turbo that im considering have a factor in the tubes sizes?I got these turbos in mind--------->
Garret T72 turbocharger
-Intake A/R is .60
-Exhaust A/R is 1.34
-Input Diameter is 5 inches O.D.
-Output Diameter is 3.5 inches
-Exhaust Diameter is 4.5 inches.
or a 91 mm Precision turbo.
Pretty big turbos might I say
Old Oct 23, 2003 | 07:15 PM
INTMD8's Avatar
From: I reached back like a pimp and smacked that LS1....
What are your goals?
Old Oct 23, 2003 | 09:39 PM
RobZ's Avatar
Hp goals no lesser than 700+on a single.My bud and I Looked at a couple of maps but still uncertain.I was thinking at first going twin with two turbonectic T72's...but later decided on a single instead.
Old Oct 24, 2003 | 09:05 AM
mongse_1's Avatar
I think that's what I'm going to use on my 76. What are you using for material? Mild steel or stainless?
Old Oct 24, 2003 | 11:28 PM
SMOKNZ's Avatar
Twin 72's??? Are you headed for well past 1300 hp?
Old Oct 25, 2003 | 02:17 PM
JordonMusser's Avatar
West South Central Moderator / Special Guest
700hp? a SINGLE t72 would do it no problem.
a 91mm is like 1500hp, ditto on twin 72s...
a t76 with the new Q trim/R wheel will be plenty
Old Oct 25, 2003 | 03:56 PM
zturbo's Avatar
700 rwhp with a t-72 is doable, I would personally prefer a lil more turbo ie 76-88 range. You could always buy my single (t-100 bb) I would do a 1.75" tubing for your setup and run it into the turbo using a smooth flowing y pipe setup. I only use stainless personally but that is cause of personal experiences with mild steel seeing what happens over time with it.
Placement of the turbo is all relitive to what you want in the engine bay though IMO and what you are willing to move around. If you move stuff around then your options are opened up alot more. If you want to leave everything in one position then your gonna limit yourself
Steven
Old Oct 25, 2003 | 04:35 PM
RobZ's Avatar
Your right 700hp is doable with a T-72,but just imagine what twin T-72 might do.,but a T-72 just alone aint gonna cut it.So Why the reason for a big turbo?Single I like single setups.As far as the tubing goes we will be using 321 SS for the exhaust and 304 SS for the intake.Im still unable to decide on the flange thickness.Ideas?
Old Oct 25, 2003 | 04:45 PM
zturbo's Avatar
Humm what goes on the end of this set of headers lol
Humm t-66's maybe lol
Twin t-72's you are in the 1600 hp range. In a stock blocked setup you can do it but would I no.. Granted I do things people think are wrong but its what make the world go round.
Reason for my using the t-100?? I have a goal and going to need a big turbo to reach the goal.
I run alum tubing to my intake no reason for the weight for stainless 304 for the intake tubing. I used mild steel for the downpipes then had them ceramic coated.
I used 1/2 inch flanges for a solid foundation. One thing I would recomend is the stall flange conversion setup. I have the stahl mounts and do not regret it they are just plain awesome. 10 mins and my headers are off.
Steven
Old Oct 25, 2003 | 06:42 PM
RobZ's Avatar
Thumbs up
Nice setup you got there Zturbo.Is that a air to water tucked on the in the inside of that passenger fender and did i just read one of two intercoolers.
Old Oct 25, 2003 | 07:34 PM
excal's Avatar
t-76 will do it no problem..
u have to realize..to make things eaiser for u, the avg joe doesn't max out a turbo to its "rated max hp".
so instead of shooting for something that's supposed to do 700hp, just get a bigger turbo that'll do it even easier.
Old Oct 25, 2003 | 10:28 PM
zturbo's Avatar
For my twin turbo setup i have a 2-230 air-water intercooler in either fender. (one on each side) The other side is identical to that one. I had finished the setup then pulled out the twins to run a single thumper.
Steven
Old Oct 26, 2003 | 12:15 PM
bad_turbo's Avatar
nothing compares to running twin turbos
Old Oct 27, 2003 | 12:19 AM
nytrus1's Avatar
Hi Guys,
just joined, awesome site,
When you call a turbo a t-76, t72, t-100 etc, Is that the inducer diameter on the compressor side or the exducer diam.
thanks
LeftoverChinese
Jan 14, 2024 03:03 PM
RUENUF
Mar 13, 2016 03:39 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
Newgmman
Feb 25, 2015 02:53 PM
blac94Z
Jan 22, 2015 11:19 PM
