S-Trim 383 Pulley Sizing Question
Old Nov 12, 2003 | 11:34 PM
Jason Dove's Avatar
I just picked up an S-Trim... and I need advice on Pulley Sizing.
My motor is a 383,w/CC305, 9.5:1 CR, and some 295 CFM flowing heads... I want to run about 8-9#'s of boost. What size of pulley am I going to need, and how close to the MAX impeller speed will I get at 6k RPM?
Thanks.
Old Nov 13, 2003 | 08:17 AM
2MCHPSI's Avatar
Looking at your setup, a 3.1 and 7" pulley should get you near your target boost level (Maybe a little more depending on where you shift). It all depends on how well that motor breathes
Old Nov 13, 2003 | 09:19 AM
Draco's Avatar
Re: S-Trim 383 Pulley Sizing Question
Thanks.
Jason,
I ran that blower . Keep the blower pulley and run the 7" crank pulley. That gave me 8 lbs on boost (I had bigger heads then you and lower compression) so you should be at 8.5-9.
I made 470 rwhp non-intercooled with ignition issues. Once those issues were cleared, I ran 122 mph in the 1/4 spinning thru first and second.
Old Nov 13, 2003 | 05:15 PM
RCF925's Avatar
I currently have an S-Trim with 6" crank pulley and 3.33 Blower pulley with 9.3:1 CR and Stock heads P&P putting out 5 to 5.5 PSI. I am probably going to go to the 6.66" crank pulley to get me to the 8 to 10 PSI range.
Old Nov 13, 2003 | 07:49 PM
Jason Dove's Avatar
I think Jazz changed the Blower Pulley, so I don't know what you had on there originally.
HectorM52
Jul 30, 2017 11:46 AM
transam_388
Mar 15, 2015 11:53 AM
cyteone
Feb 7, 2015 06:04 PM
Jason Short
Jan 19, 2015 06:34 PM
