Cam for blower motors
Old Oct 20, 2003 | 10:33 PM
z28ss96's Avatar
I'm looking for a cam recomendation for a blown 383 stroker. The motor currently has a hydrolic roller with .505/.530 lift, a 112 lobe center and a duration of 225/234. This cam is close to the Comp Cam 304 grind. I'm looking for a cam that will work great with the fuel injection, still be streetable and really wake up at the track. Any help would be appreciated. I know that this is probably an issue that keeps popping up but it's been a long time since I've been to the board...military stuff. Thanks for the help.
Old Oct 20, 2003 | 10:43 PM
93formula's Avatar
im selling one thats a 224/236
http://web.camaross.com/forums/showt...hreadid=181521
Old Oct 21, 2003 | 08:07 AM
95 Silver TA's Avatar
You can either get his cam ^
Or if you want a Higher lift version of the 224/236 cam with 114LSA from www.cmotorsports.com.
My friend "Maldo" has the lower lift version cam on his Blown 97Z and his car pulls clean and hard past 6200rpms. I believe its the same lift version as the one that 93formula is selling but here are the numbers with 1.5 Rockers (about .501in and 520ex) . If I had to do it all over again, I would have ditched the CC305(220/230 114LSA) cam for the cam I mentioned above (224/236).
Hope that Helps,
Claude
RUENUF
May 25, 2016 08:10 PM
MadMav
May 25, 2015 09:35 PM
Cam's maro
Jan 30, 2015 09:21 PM
1LEThumper
Jul 14, 2003 12:45 PM
