Idle problem/ low end miss
Old Oct 22, 2003 | 12:53 PM
NiteRyda's Avatar
After i install my PSC-1 procharger when it starts cold the idle is fine but when it warms up that when the trouble starts. The idle is
at about 500-1000 and is not consistant. On top of that it has a miss at idle but is perfect everywhere else. Has anyone had this problem befor.
NiteRyda
Old Oct 22, 2003 | 04:05 PM
steve10358's Avatar
3rd Gen Tech Moderator
I had the same thing happen. Take some carb cleaner or something wet and start spraying your vacuum lines. You have a leak.
Also- make sure none of the supplied caps shot off of the manifold fittings. I had a 3/4" leak and didnt realize it! Things are much better now.
edman
Mar 13, 2015 09:39 PM
Fatdog2
Feb 13, 2015 08:19 PM
CARiD
Jan 27, 2015 06:27 AM
Gtpguy
Jan 26, 2015 04:50 PM
