I neeed 100LB injectors or close
Old Oct 29, 2003 | 02:47 PM
sleeperz28's Avatar
Dolpi(sp)/msd makes a 96# injector but I dont agree with the quality of them for high fuel pressure applications. I have run siemans to the limits with no signs of failure. they are 72#'s, even though the injectors typically test a few pounds higher then advertised, 10 more #'s of fuel will not be enough for me to run 25psi. My 72#'s were right around 95% and I would like to keep it safe next year~80%. Siemans only makes a 83#er and the next size is 160#'s too big for the street. Im not sure if there is a good quality injector for that kind of power under boost?
I know those making my power level are limited on this board but maybe if enough of us get together we could get sieman to make use like a 110lber?
Old Oct 29, 2003 | 03:14 PM
got_hp?'s Avatar
msd makes a 96#.....$80 each from summit
siemens also makes a 140#
Old Oct 29, 2003 | 04:13 PM
Chris B's Avatar
You want to sell the 72's?
Chris
Old Oct 29, 2003 | 04:56 PM
Pro Stock John's Avatar
83lbs inj is 97.47lbs @ 60psi
Old Oct 29, 2003 | 07:02 PM
KTamez's Avatar
*shrug* Just buy some 160s. Drop the Fuel Pressure if you've already got it jacked trying to compensate. Why buy just barely enough when you can have plenty and just tune for them.
Old Oct 29, 2003 | 10:39 PM
kmook's Avatar
Advanced Tech Moderator
Do you drive it on the street at all? If not id just use the 160s. Id hate to try to get that thing to idle on the street though with those.
Siemens has 86lbs inj @ 43.5psi
http://racetronix.com/Racetronix-Del..._Sale-83s.html
Old Oct 30, 2003 | 09:36 AM
My friend figured out that stuff for ya, he said you should jack up your fuel pressure and run 83's or 95's, and that 160's will be terrible on the street.
Old Oct 30, 2003 | 12:23 PM
96 WS6's Avatar
How about using TWO 50# injectors??? I know it sounds far fetched but if you had a custom intake manifold with longer runners maybe you could put two injector ports on it instead of one. I am just thinking out loud, I'm sure tuning would be something vicious...
Old Oct 30, 2003 | 01:26 PM
mongse_1's Avatar
Damn, what kind of fuel pressure are you running to max 72# squirters? I know you're making a lot of power, but sheesh.
Check with PTE:
http://www.precisionte.com/products/...Fuel+Injectors
Old Oct 30, 2003 | 01:59 PM
JeffT's Avatar
anybody know anything about the precision injectors? Good/bad or how they compare to the Siemens?
Old Oct 30, 2003 | 02:09 PM
sleeperz28's Avatar
-Msd's are junk on blown apps.
-I dont want to crank on the fuel psi too much. its at about 70psi under full boost i think I would go about 80 max(which would be at about 25psi of boost). The more pressure I run at the rail the more pump i have to run so i want to keep pressure down so i can utilize my weldon 2025.
-My car is only a street car so I dont want to run 160's on a bank to bank driver.
-Those siemans are actually 83#'s, but as stated before they usually test a few #'s more then advertised.
-precision injectors if I remeber correctly are made by the same company as MSD(delphi)
Old Oct 30, 2003 | 02:20 PM
sleeperz28's Avatar
Chris
yeah they are 4 sale as of this monday
Old Oct 30, 2003 | 02:26 PM
JeffT's Avatar
This is the info that I got from racetronics concerning that:
83# w/ test solvent
86# w/ gas (has more mass)
Known as 83's as shown in ad:
http://www.racetronix.com/Racetronix..._Sale-83s.html
Old Mar 17, 2004 | 02:20 AM
Racetronix's Avatar
The Delphi low-z injectors do not have any problems operating at 70PSI+.
FYI GN owners commonly run Delphi 50's at high FP's even though they are considered a lazy injector.
Old Mar 17, 2004 | 06:10 PM
MIGHTYMOUSE's Avatar
i have had really good results with my high impedance mototron injectors.. i reccomend you look at their low z offerings and mabey give brian there a call.
http://www.mototron.com/prod_superstock.htm
http://www.mototron.com/prod_superstock2.htm
http://www.mototron.com/prod_superstock3.htm
