Do I have to remove my blower/brackets to install my cam??
I'm not positve on the Vortech kit, but on the ATI kit, one of the bolts for the bracket goes through the water pump. If I was doing a cam swap, I'd pull it for sure. Bottom line is that the 5 minutes it will take you to remove the bracket, will save you 20 just cause it's out of the way.
