1st Gen. Tramsmission
OK, I am currently restoring a 1969 Camaro and am putting a 4-speed in it. I don't know a lot about the 4-speed transmissions they used that year, only that they were the Muncie's. So, did they use all 3 of the M-20, 21, and 22, or did they only use certain a one (or 2) that year? Also, which one would be the best for a modestly built big block.?
All three were used; which one depended on the engine and diff ratio. A 69 SS could have an M20 if the ratio was 3.31, M21 if it was a 3.73. Factory tended not to use wide ratio (2.54 1st) M20 with the deeper gears, but special orders could have it. M22 was optional, rarely ordered.
Best for a mild big block would depend on rear end ratio, among other things. If you plan on using a 3.31 gear, wide ratio M20 would probably be best. Deeper gear, M21. If you can find an M22, grab it if price isn't outrageous.
cmsmith
Sep 14, 2015 09:25 PM
