paper behind back seat
Old Aug 2, 2003 | 09:18 PM
markrpennington's Avatar
Can anyone help with this information, this sheet was behind the upper back seat and has a lot of information on it about the car. Presumably when it was being built, does it make the car worth any more? Can anyone tell me what all the codes mean?
Old Aug 2, 2003 | 10:45 PM
angel71rs's Avatar
Sounds like a build sheet. Used on assembly line so workers knew how to build that particular car. If your car has valuable options, it can be used to prove authenticity, so it would make your vehicle more valuable in that case.
Old Aug 3, 2003 | 11:18 AM
CoryM's Avatar
For the most part the codes were nonsense unless you were in the factory. I dont think there is any record of what the assembly codes mean. However, depending on year it will list the options. Those are just the RPO codes. You can find out what these are. For example A31 is power windows, of course the most well known is Z28-special performance package. There are a few sites that list RPOs. I think www.chevy-camaro.com is the best? If its a second gen head over to www.nastyz28.com . Tons of 2nd gen info.
CoryM
Old Aug 6, 2003 | 03:27 PM
Jeff H's Avatar
What vehicle and what year? The buildsheets are different for every car every year. It would add value to the car if it's something like a Z28, SS350, SS396 or Rally Sport.
Old Aug 7, 2003 | 09:38 AM
my build sheet
thanks for the replies.
its an 81z and the cars vin matches the sheet information, when I restore it, I want everything to be like it was, but there is a lot of info on this sheet that I'm not yet sure what it means. I've come across some sites like nastyz28 and that has helped some.
Old Aug 7, 2003 | 02:35 PM
Dirt Reynolds's Avatar
It is you cars' build sheet. I too found one behind the back seat of a 1980 Z-28 I owned years ago. It tells you what dealer ordered the car, the options and so on.
cmyname1
Feb 19, 2015 08:38 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
Snoman73
Nov 17, 2014 07:22 PM
firebirdude
Aug 7, 2002 07:31 AM
dmaastr
9
Jul 1, 2002 02:22 PM
