Gauge Problem
Old Jul 12, 2003 | 07:23 AM
Steve W's Avatar
Gauge Problem
I have a 73 camaro ,and the gas gauge stays past full .The car has no gas in tank. Also my temp gauge goes to hot when I turn the switch off, Then drops down when I turn key on. The car runs, but this happens before the car has been started, so the motor cant be hot.I have replaced the circuit board behind the gauges but that did not help.It must be a short or Ground but I cant find it .If someone has had this problem please give me some advice.Thanks .
SteveW
Old Jul 12, 2003 | 01:12 PM
texlurch's Avatar
Sounds like a missing ground from the gauge panel to the body. On the back of the gauges, there is usually a male spade terminal sticking out that a ground wire goes to. Look and see if it is still on. Probably pulled off when the gauges were removed, and is hanging down in the wire loom.
Old Aug 4, 2003 | 01:58 PM
XLR8TOR's Avatar
Re: Gauge Problem
SteveW
Is the gas float in the tank stuck? If not, make sure the sender's ground wire is in contact with some bare metal.
warmeck
Mar 22, 2015 06:43 PM
mattstrike
Mar 11, 2015 07:33 PM
99TransAmWS6
Feb 12, 2015 07:23 PM
blac94Z
Nov 24, 2014 07:12 PM
slothgrant
Aug 22, 2002 03:01 PM
