Stall Converter?
Re: Stall Converter?
Originally posted by krucib1e
Hey,
Could someone explain what a stall converter is? How does this benefit your car/not benefit?
Thanks!
Hey,
Thanks!
The negatives are that slip creates heat, so you probably want to run a trans cooler.
Heres some FAQ's about torque converters and stall speed.
Converters
Check out www.torcoconverters.com!!! They are advertising there 9 1/2" billet converters for $300 !!! Sounds too good to be true, BUT ITS NOT....
From: Teeter-tottering between Brilliance and Insanity
Re: Converters
All convertors are stahl converters. Basically, stahl is the highest rpm the engine will spin before the converter supplies too much pressure and engine tops out. You really need a translock to check this. Different comanies rate their TCs differently, Brake or Flash. One of the most misunderstood things around. PLUS they react differently in different engines.
Javier97Z28
Sep 8, 2002 07:23 AM
