How do I get the window crank handle off?
Old Aug 18, 2003 | 10:05 AM
StorminNorm's Avatar
I need to get in the door panel to inspect the window mechanism (the windows are crooked and wont go up staright on their own.
Old Aug 18, 2003 | 10:29 AM
jy211's Avatar
There is a clip on the back of the handle. A skinny screw driver should be able to fit behind it and wedge the clip off. Then the handle should pull off....
Old Aug 18, 2003 | 10:32 AM
Thanks - I'll give it a shot.
Old Aug 18, 2003 | 01:10 PM
jg95z28's Avatar
There's a special tool for removing window cranks. You should be able to pick one up at your local autoparts store. (Motormite, a.k.a. Help! carries one.) Its much easier than a screwdriver although that will also work.
Old Aug 18, 2003 | 01:13 PM
Pep Boys here I come.
Old Aug 18, 2003 | 06:03 PM
Daweazel's Avatar
that special tool is called a rag just wrap the rag behind the handle and turn it like your rolling down the window. The clip will come out with no problem.
Old Aug 19, 2003 | 09:07 AM
That's even better. I havent had time to get out to an auto parts store.
Old Aug 19, 2003 | 10:52 AM
JEDCamino's Avatar
I'll have to try that next time. Thanks!
Heathen1
Jan 2, 2016 04:27 PM
willismoons
May 27, 2015 04:03 PM
TT350
Mar 31, 2015 07:44 PM
warmeck
Feb 2, 2015 12:44 AM
