Turbo 6 or BB?
Old Aug 4, 2003 | 12:55 PM
Fickle's Avatar
Turbo 6 or BB?
Well, the 1978 Chevy truck with a short bed, 3 on the column and an inline 6 is now mine. It was my grand fathers and now I get to restore it. Fun fun.
So, I'm guessing it has a 250 ci (4.1 liter) 6 right? I know a guy here that loves to build custom turbo applications so I was thinking about building the 6 and putting a HUGE turbo on it....or build a HUGE rat (496 at least).
I still plan to buy/build a 1st gen Camaro, but this will be fun for now....Plus I need a truck to pull my Camaro/trailer.
Thanks for the input!
Old Aug 4, 2003 | 04:22 PM
JEDCamino's Avatar
My dad has a '77 with the 250 and it is a great engine. Personally, I think the BB would probably be easier, but the turbo I6 would be alot more interesting. A friend of mine is working on a '65 Mustang with a turbocharged I6. He currently has an I6 on nitrous, and it is quite cool, too.
Old Aug 4, 2003 | 07:42 PM
Fickle's Avatar
Does anyone want to guess at the weight of the truck? Does 4200 lbs sound about right? A friend told me I was wasting my time if I built the truck to drag. He said it'd take 540 inches to run 10s (my goal with the truck or a 1st gen Camaro). Is he right?
Old Aug 4, 2003 | 09:26 PM
CoryM's Avatar
Its likely under 4000lbs. If its a swb 1/2 ton with no power windows etc It should be in the area of 3800-3900lbs. Just do a bigblock. THe inline6 will be too stressed out to tow with. If you do go for an I6 upgrade to a 292ci. You will lose HP but gain a ton of torque. My LWB 70 weighs 4500lbs with heavy duty everything . Going to try to get it around 3800lbs when Im done. Head on over to www.67-72chevytrucks.com The 73-87 board isnt as busy as the 67-72 but it still is a good resource.
CoryM
Old Aug 4, 2003 | 09:56 PM
Fickle's Avatar
Thanks for the info Cory!
And yeah, I was going to go with a 292 but finding aftermarket parts for that motor is next to impossible, especially if I wanted to run 25 psi into it.
Old Aug 5, 2003 | 12:01 PM
JEDCamino's Avatar
You could run 10s with just about anything, but a BB would be much easier. BTW, fast trucks are just cool.
Old Aug 5, 2003 | 05:16 PM
Fickle's Avatar
Well, I was thrown for a loop when my plans went from saving for a 1st gen Z to restoring an old C-10. I'm getting the truck for free, so I figured why not restore it and put a rat in it....I have the resources to make it fast either way, but I'm leaning towards a BB because you just can't beat the sound of a one....
Cheers
Old Aug 6, 2003 | 04:56 PM
Greed4Speed's Avatar
If you're going turbo why not look into a V6? Dont think it'll run fast? Look at the heavy GNX. There is a decent aftermarket for them also. If you want something larger than a 3.8L then go 4.6L.
Ya, a BB sounds good but so does a 6 when it's spooling up. The good thing about a 6cyl turbo is you can dial down the boost and get decent milage on pump gas then have a fuel cell w/race gas for when you crank up the boost.
You'd also have the added advantage on competition at car shows with not having a very common engine for a modified truck. If thats your thing. You'd also have a sleeper advantage on the street if you get a relatively quiet turbo.
Just my $.02. Either way, it'll be a cool project. Could have the best of both worlds and turbo the BB.
95blkss
Sep 22, 2015 03:18 PM
cmsmith
Sep 14, 2015 09:09 PM
NewsBot
Sep 14, 2015 02:02 AM
sleeperZ96BT
Sep 10, 2015 08:01 AM
LeftoverChinese
Jul 23, 2015 03:57 PM
