How do i shimm a distributor?
Old Aug 4, 2003 | 09:52 PM
shockers69's Avatar
Question How do i shimm a distributor?
I am in the last stage of my engine swap on my 69 Camaro the MSD dist. had a bronze gear on it for the roller cam now that i have switched to a flat tappet cam i need to go back to the stock gear how do i know if it needs shimms or not?
Old Aug 5, 2003 | 07:51 PM
roadblock's Avatar
Once the gear is mounted to the shaft you measure the gap between the gear and the housing. There is a washer installed there normally. Chervolet used to make a shim kit but I think that they no longer do that. That shim kit was simply washers to fill the gap between the gear and the existing washer. I do not remember the clearance specified but I sort of remember it being in the .0035 range.
68camaroboltz
Oct 5, 2015 01:46 PM
94Z28LS1toLT1
Oct 4, 2015 11:28 PM
autoxr166
Sep 25, 2015 04:21 PM
1995Blackz28
Jul 20, 2015 09:34 AM
gonzo275rltw
Jul 11, 2015 04:19 AM
