Need help on header gaskets on zz4
Old Aug 21, 2003 | 04:09 PM
shockers69's Avatar
Question Need help on header gaskets on zz4
Man i am having trouble finding someone that knows anything local about a zz4 i need to know which one to get summit sells 10 different kinds the first brand being Percy's 1 called small chevy round 2nd. small chevy square.Earl's sells 6 different kinds for SB Chevy or i can get Flotech brand dead soft alum.at my local speed shop since my alum. heads have a D shaped exhaust port will these square shaped Flotech work?I have another problem i have Dynomax 1 5/8 that i want to use on these heads so i want a gasket that will last and not leak.Please help!!!
Old Aug 21, 2003 | 06:18 PM
Erik's Avatar
Classic Tech Moderator
I use Felpro blue gaskets on my ZZ4 - they work great.
btw, GM reccomends 1 3/4" primary headers.
Old Aug 22, 2003 | 01:32 PM
Z28SORR's Avatar
Whether it's a ZZ4 or not is really irrelevant. What is important is that you get headers that fit the exhaust ports. The primary flange hole has to be large enough to fit over the entire exhaust port. Then you match the gasket to the headers. I believe with "D" ports, round header primaries are recommended.
dylan1303
May 22, 2015 12:24 PM
4586
Apr 29, 2015 01:43 PM
94Z28LS1toLT1
Apr 7, 2015 05:37 AM
rick350
Mar 16, 2015 02:59 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
