Got a problem with my AFR guideplates...
Old Dec 16, 2002 | 08:37 PM
aBrotze's Avatar
I was in the process of adjusting my rocker arms and a friend noticed a few of the rocker arms did not look properly aligned on top of the valve stem. I was wondering what folks have done to correct this?.
Old Dec 16, 2002 | 08:40 PM
Jason Short's Avatar
Intake side? I had the exact same problem.....had to use different guideplates AND had to run .150" offset rockers on the intake side
AFR 210's
Hope yours doesnt require that.....I never did figure out why that was. No one had had that problem before....until now I guess
Jason
Old Dec 16, 2002 | 08:44 PM
OneFlyn95z28's Avatar
Jason nailed it. you can get close with Isky adjustable plates(make sure you weld them) but they move the intake port over a bit to far
Old Dec 16, 2002 | 08:45 PM
aBrotze's Avatar
Now that you mentione it.. The first one I noticed was the intake on #1. Saw several others but do not remember if they where intake or exhaust...
Old Dec 16, 2002 | 08:49 PM
aBrotze's Avatar
Talking
Hey ... Just noticed the number of post by me is 396
Old Dec 16, 2002 | 10:39 PM
onebadponcho's Avatar
Question
Check this out:
http://web.camaross.com/forums/showt...ht=guideplates
I'm looking for answers myself. I called Comp Cams earlier today and they haven't heard anything about this.
Old Dec 16, 2002 | 11:59 PM
LMFAO!!!
We talked to them in the spring...more then once!
Old Dec 17, 2002 | 10:25 AM
aBrotze's Avatar
I did not realize this but the AFR guide plates have different lenght slots. The longer one should go on the exhaust. This is my problem. I guess I still have not learned to read ALL the paper work that comes with the product!!!!
95chwagon
May 27, 2015 09:53 AM
Potent77
Apr 1, 2015 12:45 AM
pimpss96
Feb 12, 2015 01:28 PM
MadMav
Feb 6, 2015 11:02 PM
95chwagon
Jan 13, 2015 09:19 PM
