Throttle body size
Old Nov 24, 2002 | 06:39 PM
lt4 fd's Avatar
Throttle body size
Just wondering how you know when its time to move up. I know some people swear that 48mm is big enough and some say go bigger, but I was wondering if there is any way of telling... like from manifold absolute pressure, I am getting tuner cat so just wondering if theres another way other than guessing.
Old Nov 24, 2002 | 10:25 PM
NOMAD's Avatar
Cool
Search in LT-1 tech since this has been beat to death about 2 times a week and isn't really advanced I know myself and Fred awnsered in a single post just yesterday on the same subject.
-Shannon
Old Nov 25, 2002 | 12:23 AM
SStrokerAce's Avatar
Simple rule is that you really should care about the CFM level. A 48mm probably is not enough at any level, while a 52mm will be. Then when you move up to the 1000cfm then you have a engine on your hands and that will support 650 hp, I think that the 1300cfm Monoblade is a bit much for almost anything, but it can't hurt if you have a ton of power.
Bret
Old Nov 25, 2002 | 01:39 AM
Jimmy17's Avatar
there was just a post yesterday in lt1 tech i beleive, something like this:
396 engine at 104% VE spinning 7200rpm, takes in 866cfm
so a 58mm supporting 1000cfm only needs to be 86% open to get WOT
or.... a 52mm should be able to get full power when fully open
makes sense to me
if i was buying one though (and probly wouldnt until making over 400hp?) i'd probly just go ahead and get a 58mm for (maybe?) crisper throttle response and room for growth
doesnt seem a 1300cfm monoblade would be necesary for any small block application thoguh
Old Nov 25, 2002 | 07:47 AM
Z28tt's Avatar
CFM is measured at a specific pressure drop - i.e. vacuum or restriction. The rated CFM is at a restriction, however small. If you don't mind that restriction, stick to CFM numbers.
A.
Old Nov 25, 2002 | 01:14 PM
jimlab's Avatar
Doesnt seem a 1300cfm monoblade would be necesary for any small block application though.
Perhaps, or perhaps not. It is perhaps worth noting, however, that three of the most powerful pump gas NA LT1s that I know of all use an Arizona Speed & Marine 1300 CFM monoblade.
Phil Tobin's 403 ("Hoover")... 500 RWHP and 456 RWTQ
http://phil.tobin.net/Hoover/modifications.html
Brian Bieller's 396... 597 BHP and 481 lb-ft.
http://www.lt1motorsports.com/streetfighter.htm
My 396... 647 BHP and 552 lb-ft.
http://www.c-zone.net/markm/JimLaBre...d/P1190044.JPG
Old Nov 25, 2002 | 02:02 PM
Denny McLain's Avatar
Jim
That's an awefully snazzy looking motor you have. Are those AFR 215 heads? Also what compression are you running? Is the motor streetable?
Old Nov 25, 2002 | 03:31 PM
jimlab's Avatar
Thanks, yes, 11.8:1 according to Mark, and yes, on pump gas.
Old Nov 25, 2002 | 06:03 PM
Guess the word of the day is: congratulations.
You certainly caught my eye.
Peytons'z
May 6, 2021 09:25 AM
HectorM52
Jul 30, 2017 11:46 AM
QuickSilver02
Apr 7, 2015 11:12 AM
4586
Parts Wanted
Mar 17, 2015 11:24 PM
Jul 4, 2005 05:00 PM
