Speed Pro Hellfire rings
Old Dec 1, 2002 | 09:20 PM
VX355's Avatar
I am re-ringing my blower motor and have been reading about these new rings from speed pro made for nitrous and blower cars. Does anyone have a good dealer or someone I can discuss this with. I dont really like calling summit or jegs, I like a real motor builder or someone who has used them quite a bit. Thanks
Old Dec 2, 2002 | 08:23 PM
Mindgame's Avatar
Re: Speed Pro Hellfire rings
I know a guy running them in a very high output nitromethane car. He's just an aquaintance so I don't get the whole story but the guy swears by them. The only thing is, the piston has to be specially machined to use them because of the stepped ring.
If I were looking to build a really high output (3 hp per cubic inch+) engine, then I'd definitely look into using these rings. Best bet is to talk with Speed Pro directly. HTH.
-Mindgame
Old Dec 2, 2002 | 11:25 PM
KTamez's Avatar
Call Sonny Leonard.
My understanding is these rings can only be bought individually. You'll have to buy an entire set of rings (Oil rings etc), AND the Hellfire rings.
Sonny's can sell you ONE set of rings w/ Hellfires. Also, I'm sure they can explain what you need to do to use them, or if you *should* use them.
They'll be in my engine next time it needs freshened.
Old Dec 3, 2002 | 12:42 AM
OneFlyn95z28's Avatar
Arron aka Ponyeater has a set in his new motor.
Check the pacific NW section to get ahold of him
Old Dec 3, 2002 | 11:14 PM
VX355's Avatar
Thanks for the replies, do you happen to have Sonnys number on you by chance. Or does he own a shop I can call, thanks again for the help
Old Dec 4, 2002 | 07:44 PM
KTamez's Avatar
http://www.sonnysracingengines.com
Old Dec 4, 2002 | 09:03 PM
PONYEATER's Avatar
I have had them on this motor for less then 100miles and I did a leakdown that was less then 1% hot around 2% cold They seem to work very well.
DirtyDaveW
Dec 1, 2016 05:37 PM
carl.froehlich
Mar 13, 2015 12:38 AM
D1SC383LT4
Jan 26, 2015 01:41 PM
Speeds8erM-1
Jul 18, 2002 11:36 PM
