offsetting crank
Old Dec 3, 2002 | 06:47 PM
1BadBrd's Avatar
offsetting crank
i read something about offsetting the crank. It was in hot rod mag. and had a special with 25 new trick to building an small block. Looked very intresting, i can explain more when i get the mag from my friend. I read it breifly and want to know if this was risky or what. I will ask later about what set up i was thinking about. Instaed of stroker i was thinking of this offset crank with new rods and pistons.
http://home.wanadoo.nl/a.van.diggele/crank.htm
The only way i can explain it is that you take the center point of the crank and move it up or down by a fration then you shape the crank lobe or journal maybe is what you call it, to a certain size and you get a certain stroke then.
Old Dec 3, 2002 | 08:23 PM
OneFlyn95z28's Avatar
Basicly same thing as a stroker
Many times you can pick up stroke by grinding the Rod center lines off center(and out,increasing stroke) and going to a smaller rod journal size.
I would just buy a new crank. Then again if you took a 396 crank(3.875) and did this with a old 327 Rod journal it would still clear the cam and pick up even more stroke
Good luck!
Henson071
Dec 30, 2015 09:55 PM
Novo
Wheels and Tires
14
Oct 12, 2015 11:20 AM
95craz28
11
Sep 12, 2015 07:47 AM
Daluchman1974
Sep 11, 2015 06:12 AM
Catmaigne
Jul 14, 2015 05:17 PM
