clearancing for sbc 383 stroker
Old Dec 12, 2002 | 01:20 PM
94z'sson's Avatar
where does the block need to be clearenced to fit a 3.750 stroke crank and a 5.7 rod? is there also a need to clearance the oil pan rails?
Old Dec 12, 2002 | 05:58 PM
TunedPort 335's Avatar
Although every block is not cast the same.. here are some general ideas of where you need to grind:
1. Bottom of cylinder wall near the camshaft.
2. Oil pan rail.
3. Back of the block in the corner... near the thrust bearing (because the crank throw will usually hit it) near cyl #8 I beleive.
4. There are notches near the oil pan rail that GM already clearanced out from the factory, you will need to clearance those more.
5. Oil pan (usually)
6. I also had to clearance my oil pump (because of the crank throw).
I did all the grinding with my father, we used a Dremel tool with grinding bits. Just take your time and you'll be all set
Old Dec 13, 2002 | 11:16 AM
graham's Avatar
More than likely a couple of rod bolts will have to be ground on to clear the camshaft.
Just put the crank in, spin it over, and start putting rods/pistons on one at a time. Each time, spin it over, see where it hits, and do the clearancing.
BTW: Whats the clearance? 0.100" for heat expansion right?
G-BODYT56
Jan 14, 2022 11:14 PM
Z Power
Sep 19, 2015 11:19 PM
cristian1311
Sep 12, 2015 08:16 PM
95craz28
11
Sep 12, 2015 07:47 AM
sleeperZ96BT
Sep 10, 2015 08:01 AM
