vortec heads and manifold
Old Dec 11, 2002 | 11:15 PM
99huggerorangeZ's Avatar
Question vortec heads and manifold
i have a 1991 camaro and i am replacing the stock heads and manifold with vortec heads and a vortec manifold
the heads are good up to .475 lift but am putting new comp springs that will hold up to .575 lift
and i was going to replace the stock cam with a comp XE 282 roller cam
but i am not sure if my 305 tbi will be able to handle it?
i also know that if i do this i will need to reprogram my ECM correct?
Old Dec 11, 2002 | 11:18 PM
Question bore on a stock 305
what is the bore on a stock 305?
Old Dec 12, 2002 | 12:15 AM
3.736"
Old Dec 12, 2002 | 12:23 AM
can i put on a set of cast vortec heads on a 305
Old Dec 12, 2002 | 12:39 AM
AdioSS's Avatar
West South Central Moderator
yup, but you might want to have them milled a bit to get some compression back.
You might consider the L30 heads. The L30 was the Vortec 305
Old Dec 12, 2002 | 12:42 AM
Question
when you say milled what do you mean by that
Old Dec 12, 2002 | 07:50 AM
dabear95's Avatar
Milling is removing material from the base of the cylinder head to create a good surface for gasket sealing (not warped) and as already stated to lower compression.
Jason
Old Dec 12, 2002 | 10:14 AM
I'm going to try merging this with your post on the Vortec heads....
dawg irocz
3rd Gen / L98 Engine Tech
Feb 10, 2015 10:33 AM
Chris Anderson
Jan 27, 2015 08:30 AM
InfernalVortex
Jan 17, 2015 09:35 AM
markaubuchon
Jan 14, 2015 01:48 AM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
